Attached is 20 second clip for PBS TV show capture. What software can be used to extract closed captions?
Why do you think this has CC?
From what I can tell, it doesn't. Nothing parsed in MediaInfo, not available in WMP or VLC or Quicktime (though they should have the option if it were available).
File is 656x480.
Many times, the analog VBI is encoded & stored in e.g. a 640x486 file (notice the extra rows - often used for the VBI).
Video stream is Xvid (aka MPEG4-ASP), CC OUGHT to be stored as EIA-608 or EIA-708-formatted text.
Normally, I'd use CCExtractor or some other McPoodle tool. Doesn't look like you have one this time.
Was encoded with Boilsoft...so, not surprised.
Scott -
I thought all PBS shows had closed captions. The show that I got was 1 hour long. I used Boilsoft to slice out a 20 second clip. I don't think this editing would have eliminated the closed captions. Could the method of capture (or subsequent encoding) preserve/eliminate the closed captions?
Closed captions in SD analog video is carried on line 21 of the video signal. Some cards capture line 21 and you can see the encoded CC as short flickering horizontal white line segments on a black background at the top of the frame. Your capture card didn't capture that. Or did you crop them away?
Here's one tool that can read the analog CC if the captured video includes line 21:
http://www.pixeltools.com/tech_tip_closed_captioning_line21.html
Another was mentioned in a thread a few months ago.
https://forum.videohelp.com/threads/360543-Extract-captions-from-digitized-VHS-%28DV-AV...=1#post2284185
You can see the CC on the top line of the sample frame in that thread.Last edited by jagabo; 1st Mar 2014 at 08:04.
Well, this particular capture was captured by somebody else, so I don't know what capture method they used. However, for the sake of discussion, I have an official EZcap capture device that I capture from the analogue output of the on-air digital-to-analogue converter. Do you think this method would preserve the closed captions? I suppose I could use the above methods to find out.
For that to work (at least with CCExtractor), the EZcap's drivers must support closed captions, and its capture software must use a Direct Show MPEG-2 encoder filter that is able to capture closed captions as GOP user data. Not all capture devices and capture software provide those features.
Yes, some capture drivers decode the CC on line 21 and output them to the CC pin of the capture filter.
Remove Closed Captions?
By Mz Patti in forum SubtitleReplies: 6Last Post: 7th Sep 2013, 02:10 -
Can't extract closed captions / subtitles from a Tivo file.
By 1J1 in forum SubtitleReplies: 3Last Post: 9th Mar 2013, 08:02 -
Question how to extract Closed Captions (cc) from VCR tape
By jimdagys in forum SubtitleReplies: 8Last Post: 24th Jul 2009, 16:48 -
No Closed Captions on Computer, Only TV
By JimBarbasol in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2009, 18:17 -
Closed Captions and ProjectX
By sambat in forum DVB / IPTVReplies: 12Last Post: 29th Mar 2009, 04:41
