I have an Apex-1500 DVD player.
I have encoded many clips into MPEG-1 and 2 format and all have played on this player. Some though will sputter during the clip and slow down or freeze for a few seconds and then speed right back up.
What would be the cause of that? My guess is that the video data isn't being transferred off of the CD fast enough due to the CD's data density being less than that of a DVD.
This posts is merely a question as to whether that could be a reasonable explanation![]()
what is the bitrate of the mpeg?
I have a AD-1000, and anything above 4000 Mb/sec studders. -
I don't have the files with me right now (I'm at work
) but I think they are over the 4000 Mbps limit you mentioned. Now DVDs are encoded at 8000 Mbps so why don't they stutter too? Again is it because the player can't read the information off of the CD fast enough?
yes, Im guessing that is the reason.Again is it because the player can't read the information off of the CD fast enough?
you can get more info here
http://www.nerd-out.com/forum/viewforum.php?f=1&sid=419f7ec84fcfe62f965fc65312f4efcc
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Panasonic PT-61LCX65 spotty picture....HELP!
By farside792 in forum DVB / IPTVReplies: 1Last Post: 29th Dec 2009, 13:21 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg 2 file is not playing at the correct speed maybe 2% fast
By Gun4u in forum Video ConversionReplies: 4Last Post: 23rd Apr 2008, 23:20 -
Replacement for Apex AD-1500
By siskiou in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Mar 2008, 23:59
