Results 1 to 24 of 24
  1. Hi
    I am trying to combine a video and audio stream from youtube with ffmpeg on a linux (kubuntu) box. I run the command
    "ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -vcodec copy -acodec copy darktablefinal.mp4"
    but all I get is a small file that only has the audio. Have tried it with the 720 video stream and same result. Terminal output is listed below.
    rob-carly@rob-carly-P5KR:~/Downloads$ ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -vcodec copy -acodec copy darktablefinal.mp4
    ffmpeg version 0.8.10-6:0.8.10-0ubuntu0.13.10.1, Copyright (c) 2000-2013 the Libav developers
    built on Feb 6 2014 20:53:28 with gcc 4.8.1
    *** THIS PROGRAM IS DEPRECATED ***
    This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '_mediumDarktable_Equalizer_module':
    Metadata:
    major_brand : dash
    minor_version : 0
    compatible_brands: iso6mp41
    creation_time : 2014-02-14 14:36:55
    Duration: 00:32:34.19, start: 977.095692, bitrate: 63 kb/s
    Stream #0.0(und): Audio: aac, 44100 Hz, stereo, s16
    Metadata:
    Input #1, mov,mp4,m4a,3gp,3g2,mj2, from 'Darktable_Equalizer_module_hd1080.mp4':
    Metadata:
    major_brand : dash
    minor_version : 0
    compatible_brands: iso6avc1mp41
    creation_time : 2014-02-14 14:37:39
    Duration: 00:32:34.00, start: 977.001000, bitrate: 759 kb/s
    Stream #1.0(und): Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 25 tbr, 90k tbn, 50 tbc
    Metadata:
    Output #0, mp4, to 'darktablefinal.mp4':
    Metadata:
    major_brand : dash
    minor_version : 0
    encoder : Lavf53.21.1
    Stream #0.0(und): Video: libx264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=2-31, 25 tbn, 25 tbc
    Metadata:
    Stream #0.1(und): Audio: libvo_aacenc, 44100 Hz, stereo
    Metadata:
    Stream mapping:
    Stream #1.0 -> #0.0
    Stream #0.0 -> #0.1
    Press ctrl-c to stop encoding
    frame= 0 fps= 0 q=-1.0 Lsize= 15309kB time=977.10 bitrate= 128.4kbits/s
    video:0kB audio:14980kB global headers:0kB muxing overhead 2.199408%
    Anyone have any ideas? Am I missing a library or something?
    Cheers
    The video seems a bit different. Have you converted them yourself with exact same settings?
    You can also try join with mp4box.
  3. have you tried adding '-map 0:1' and '-map 1:0'
  4. tried this command (I presume that is the right way to use '-map 0:1' and '-map 1:0' ?)
    ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -vcodec copy -acodec copy -map 0:1-map 1:0 darktablefinal.mp4
    and it gave the error
    "Unable to find a suitable output format for '1:0'"
    Video file is as downloaded, nothing has been changed with it.
  5. there need to be a space, also I would rearrange the parameters
    ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -map 0:1 -map 1:0 -vcodec copy -acodec copy darktablefinal.mp4
    You downloaded audio&video separately?
  6. Yep, realised the need for a space as soon as I commented haha
    Using the above command I get the error
    "Could not find input stream #0.1"
  7. try:
    ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -map 0:0 -map 1:0 -vcodec copy -acodec copy darktablefinal.mp4
  8. Not sure if that was the whole command you posted? It gives the error "Missing argument for option 'vcode'"
  9. fixed,..
  10. thanks - now I get the error "Codec type mismatch for mapping #0.0 -> #0.0".
    Full terminal output is as follows -
    rob-carly@rob-carly-P5KR:~/Downloads$ ffmpeg -i _mediumDarktable_Equalizer_module -i Darktable_Equalizer_module_hd1080.mp4 -map 0:0 -map 1:0 -vcodec copy -acodec copy darktablefinal.mp4
    Metadata:
    major_brand : dash
    minor_version : 0
    Metadata:
    Metadata:
    major_brand : dash
    minor_version : 0
    Metadata:
    File 'darktablefinal.mp4' already exists. Overwrite ? [y/N] y
    Stream #0.0: Video: [0][0][0][0] / 0x0000, q=2-31, 200 kb/s, 90k tbn
    Stream #0.1: Audio: [0][0][0][0] / 0x0000, 0 channels, 200 kb/s
  11. Changing the command so the video file is first
    "ffmpeg -i Darktable_Equalizer_module_hd1080.mp4 -i _mediumDarktable_Equalizer_module -map 0:0 -map 1:0 -vcodec copy -acodec copy darktablefinal.mp4"
    doesn't throw an error but it doesn't create a file with any video either, just an audio file.
    Full terminal output:
    rob-carly@rob-carly-P5KR:~/Downloads$ ffmpeg -i Darktable_Equalizer_module_hd1080.mp4 -i _mediumDarktable_Equalizer_module -map 0:0 -map 1:0 -vcodec copy -acodec copy darktablefinal.mp4
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Darktable_Equalizer_module_hd1080.mp4':
    Metadata:
    major_brand : dash
    minor_version : 0
    Stream #0.0(und): Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 25 tbr, 90k tbn, 50 tbc
    Metadata:
    Input #1, mov,mp4,m4a,3gp,3g2,mj2, from '_mediumDarktable_Equalizer_module':
    Metadata:
    major_brand : dash
    minor_version : 0
    Stream #1.0(und): Audio: aac, 44100 Hz, stereo, s16
    Metadata:
    Metadata:
    major_brand : dash
    minor_version : 0
    Metadata:
    Metadata:
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #1.0 -> #0.1
    frame= 0 fps= 0 q=-1.0 Lsize= 15309kB time=977.10 bitrate= 128.4kbits/s s/s
  12. as a side note:
    since audio&video length differ by 20 seconds you output will be asynchronous.
    Why did you download audio and video separately?
    Strange, just tried:
    ffmpeg -i test.264 -i test.aac -vcodec copy -acodec copy -map 0:0 -map 1:0 "test.mp4"
    and the output is a file with audio&video
    and according to your the ffmpeg output you posted both audio&video get copied.
    Have you tried playback with ffplay?
    What does
    ffmpeg -i darktablefinal.mp4
    output?
    btw. to make your posts more readable: use code- and/or quote-tags
  13. as far as I can tell, youtube 1080 clips are seperate video and audio clips now - would be very happy to proved wrong on this as it means I wouldn't have to try and mux them! (clip is at https://www.youtube.com/watch?v=zzVXK4eAM5E&list=PLmvlUro_Up1NBX7VK8UUuyWo1B468zEA0&index=16)
    Have only tried playback with VLC - the output file is very small as well - 15 meg when the original video file is 177 meg.
    running
    gives
    rob-carly@rob-carly-P5KR:~/Downloads$ ffmpeg -i darktablefinal.mp4
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'darktablefinal.mp4':
    Metadata:
    major_brand : isom
    minor_version : 512
    compatible_brands: isomiso2avc1mp41
    Duration: 00:16:17.09, start: 0.000000, bitrate: 128 kb/s
    Stream #0.0(und): Audio: aac, 44100 Hz, stereo, s16, 125 kb/s
    Metadata:
    At least one output file must be specified
  14. as far as I can tell, youtube 1080 clips are seperate video and audio clips now - would be very happy to proved wrong on this as it means I wouldn't have to try and mux them
    using 'DownloadHelper' inside Firefox I can download a normal mp4 with audio and video in it,...
    General
    Complete name                            : Darktable_ Equalizer module.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42
    File size                                : 128 MiB
    Duration                                 : 16mn 17s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 096 Kbps
    Encoded date                             : UTC 2014-02-14 14:39:33
    Tagged date                              : UTC 2014-02-14 14:39:33
    gsst                                     : 0
    gstd                                     : 977095
    gssd                                     : B4A7D0DA5MH1393327177241907
    gshh                                     : r19---sn-4g57lnlz.googlevideo.com
    Video
    Format profile                           : High@L3.1
    Format settings, ReFrames                : 1 frame
    Format settings, GOP                     : M=1, N=60
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 16mn 17s
    Bit rate                                 : 902 Kbps
    Maximum bit rate                         : 4 526 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 fps
    Bits/(Pixel*Frame)                       : 0.039
    Stream size                              : 105 MiB (82%)
    Tagged date                              : UTC 2014-02-14 14:39:42
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 16mn 17s
    Bit rate mode                            : Variable
    Bit rate                                 : 192 Kbps
    Maximum bit rate                         : 202 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 44.1 KHz
    Stream size                              : 22.4 MiB (18%)
    Title                                    : IsoMedia File Produced by Google, 5-11-2011
    Encoded date                             : UTC 2014-02-14 14:39:38
    -> you might want to switch you download method,..
    Also as a general note:
    Do not use ffmpeg for mp4 (or mkv) multiplexing use MP4Box or L-SMASH (or mkvmerge in case of mkv files) for multiplexing.
    Only use ffmpeg for multiplexing (mp4/mkv files) if:
    a. you only use something that is libav based for playback
    b. you can't avoid it since you are doing a live capture (in that case if possible, the output should be remuxed with NMP4Box/..)
    Cu Selur
  15. Yes, I think that is the 720p version not the 1080p version.
    YouTube uses Dynamic Adaptive Streaming over HTTP (DASH) for delivering videos and along with that, it serves the audio and video in two separate streams for some resolutions/formats. For instance, resolutions like 1080p and 480p are available only with separate audio and video streams. (from http://www.webupd8.org/2014/02/video-downloader-youtube-dl-gets.html)
    I can grab the 720 version as well using flashgot for firefox, now I'm just kind of puzzled as to why I cant grab the 1080p video and audio and mux it back together
  16. Ah, didn't know the switched to DASH for 1080p clips.
  17. What command do I need to feed to MP4Box to mux these two files?
  18. Code:
    mp4box -add "path to video" -add "path to output" -new "path to output.mp4"
  19. Code:
    mp4box -add Darktable_Equalizer_module_hd1080.mp4 -add _mediumDarktable_Equalizer_module -new darktable.mp4
    gives the output
    mp4box: command not found
    Not having much luck!!
  20. Actually, think I will stick with the 720p clip - thanks for all your help Selur
  21. depending on the distribution it might be MP4Box instead of mp4box,..
  22. BINGO!! Yup - that was it (not sure why I didn't check that, it's late at night here in Australia)
    Files combined ok using the following command.
    MP4Box -add Darktable_Equalizer_module_hd1080.mp4 -add _mediumDarktable_Equalizer_module.aac -new darktable.mp4
    Again, many thanks, much appreciated
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    No problem.
  24. Member
    Mar 2013
    New York
    Hello,
    Im new to all this so here goes:
    Im using ffmpeg to convert mkv to mp4 for personal use. Im trying to take my son favorite movies for use on his dlna player. The dlna server is an Iomega personal Cloud running Twonky 7.2.6-2. The player is a LG BP620c latest update applied. The player can't pause, fast forward, rewind mp4. The ones I have got from friends created with mp4box I think, do. The ones I create not at all but they do play. Here is my batch file
    chcp 1252
    "C:\Temp\x264\ffmpeg.exe" -i "D:\MKV\%.mkv" -vcodec libx264 -acodec libvo_aacenc -map 0:0 -map 0:1 -map_metadata 0 -metadata mime-type="video/mp4" -r:a 48000 -b:a 192k -b:a 192k -ac 2 -af volume=3.00000 -coder 1 -threads 0 -q:v 1 -b:v 1600k -minrate:v 1M -maxrate:v 25M -bufsize:v 30M -r:v 23.976 -x264opts rc_lookahead=50 -vf crop=iw-0-0:ih-40-40:0:40,scale=720:400 -s 720:400 -aspect 16:9 -pix_fmt yuv420p -level 41 -refs 6 -deblock -2:-2 -partitions all -me_method hex -me_range 32 -subq 7 -trellis 2 -b-pyramid 0 -b_strategy 2 -chromaoffset -4 -qmin 10 -qmax 51 -nal-hrd vbr -f mp4 -movflags +faststart -an -c: s copy -passlogfile "C:\Temp\%.log" -pass 1 -y "NUL.mp4"
    "C:\Temp\x264\ffmpeg.exe" -y -i "D:\MKV\%.mkv" -vcodec libx264 -acodec libvo_aacenc -map 0:0 -map 0:1 -map_metadata 0 -metadata mime-type="video/mp4" -r:a 48000 -b:a 192k -b:a 192k -ac 2 -af volume=3.00000 -coder 1 -threads 0 -q:v 1 -b:v 1600k -minrate:v 1M -maxrate:v 25M -bufsize:v 30M -r:v 23.976 -x264opts rc_lookahead=50 -vf crop=iw-0-0:ih-40-40:0:40,scale=720:400 -s 720:400 -aspect 16:9 -pix_fmt yuv420p -level 41 -refs 6 -deblock -2:-2 -partitions all -me_method hex -me_range 32 -subq 7 -trellis 2 -b-pyramid 0 -b_strategy 2 -chromaoffset -4 -qmin 10 -qmax 51 -nal-hrd vbr -f mp4 -movflags +faststart -c: s copy -passlogfile "C:\Temp\%.log" -pass 2 "C:\Temp\%.mp4"
    "C:\Temp\x264\playsound.exe" C:\Temp\x264\Done.mp3
    pause
    Can you see a reason for my issue or a better was to improve the script?
