I reinstalled Windows 7 as usual and as I do several years ago.
But this time, the files with extension SRT had a blue icon and now they have a white icon and there are any program present to open them easily! What can I do to put back the anterior situation for ALL the files with that extension?
When I try to open those files it doesn't appear the usual window with "Choose default program" but a window "File type helper"!!!
Try ExtensionManager, it's in English, too.
Uninstall File type helper from Control panel -> Programs and Features
and Set in Default Programs Editor to always open Choose default program for Unknown type files:
Thanks to everyone that helped me.
I solved the problem with the suggestion of netmask56.
roma_turok : I installed Default Programs Editor but the respective window already shows " ... Disable ... ". -
OK.But I never ticked or unticked that. And I reinstalled Windows 7 several times and only now happenned this. I don't understand!
Thank you very much.
Converting sup files onto srt
By carlmart in forum SubtitleReplies: 12Last Post: 6th Jun 2016, 16:49 -
2 srt files to combine - how?
By jlrm365 in forum SubtitleReplies: 7Last Post: 17th Apr 2016, 07:15 -
Help Joining Two .srt Files As One
By bigb_y2g in forum EditingReplies: 18Last Post: 6th Nov 2015, 09:07 -
how to play "eps" extension files ??
By vikas.babu in forum Software PlayingReplies: 9Last Post: 2nd Jun 2010, 19:08 -
Joining SRT files
By jeromezone in forum SubtitleReplies: 1Last Post: 22nd Nov 2009, 12:09
