Yes, composite is sufficient for VHS signal, but other components in the chain have something else to interpret, including the capture device, which is why we should always use s-video if possible.Originally Posted by 2Bdecided
Profound indeed. And I'm sure I'm not the only one experiencing this rollercoaster in this hobby.Originally Posted by 2Bdecided
Even in this case it happened. Couldn't figure out an acceptable way to remove the crosstalk/dot crawl from my composite captures, so settled with a restoration solution instead. It was a simple - just downsize and then upsize. Problem solved. It "worked". (Elation!) Then, one day I noticed the artifacts from upsizing. (Horror!)
Then I found a better way to increase the resolution. (Super Resolution as a VDub filter works best for me). It took a while before I became comfortable saying that now "this works".
Results 31 to 35 of 35
I hate VHS. I always did.
Catching up on threads since I haven't been on for the past two months...
This claim has been tossed around a lot over the years but I've yet to see evidence.
On the contrary, here is a sample of the garbage at the end of a VHS tape. It starts with pure noise (obviously difficult to encode). Sharpen it, blow it up. There's no appearance of DCT artifacts. Also, the chroma resolution exceeds 4:2:0. -
Yes, this has been thoroughly debunked. I can't say there are none that compress/decompress but the the Pansonic ES15 I have shows no evidence of compression/decompression. No macroblocking, no DCT ringing artiacts, no significant loss of small low contrast detail, etc.
Yes, it's been a couple of months and have been enlightened on this recently - thanks to all, including Jagabo, Orsetto and others.Originally Posted by vaporeon800
As for debunking - yes and no. And here's my take on this confusion from what I've read.
There IS filtration that does take place, and some compromise, however such "degradations" or "artifacts" these passthrough units create become ever more frivolous since VHS video is so bad to begin with (noisy, lo-rez, soft, low color info, unstable and changing signal throughout, etc, etc).
Those that notice these deltas in P/Q may not be wrong, but can be counter argued with the fact that due to the low-band quality of VHS it's all moot.
I don't use one of these units, so only summarizing my take on what I've read on them.
It may seem interesting to know how these passthroughs perform on higher quality sources, such as high quality SD TV, but again, this may be moot as well since you shouldn't need such a unit in the chain as a TBC to clean a signal that shouldn't need it to begin with anyway.Last edited by PuzZLeR; 25th Apr 2014 at 10:33.
Help me to upgrade my little home capture system [VHS]
By TheCage in forum Capturing and VCRReplies: 6Last Post: 8th Feb 2013, 09:32 -
VHS archiving, help me select a workflow?
By 550sc in forum Video ConversionReplies: 6Last Post: 19th Oct 2011, 13:16 -
VHS to DVD workflow
By robjv1 in forum RestorationReplies: 3Last Post: 26th Feb 2010, 10:59 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 14:34 -
I an a newb. Can you pros please review my workflow and I have one prob...
By homeofficeservices in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2009, 20:01
