Results 1 to 23 of 23
  1. hi
    ive got an old cannon mvx 450 mini digital camcorder. [tape and sd card] . instructions say i can transfer video to a pc but i need a capturing card , can anyone advise me as to what this is.
    i dont have or want firewire, i do have usb 2 cable supplied
    thanks
  2. Member turk690's Avatar
    Jul 2003
    ON, Canada
    The Canon MVX450 is a mini-DV camcorder. You have to have or want a FireWire card/interface because that is the only way to get DV AVI off the tape, no two ways about this; tough. USB is only for stills and/or low-res versions of video from the SD card.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  3. ah well that answers another question which is why was the footage i recorded to the sd card such low quality in my pc.
    the cam has 2 sockets one marked DV other marked with a 3 pronged fork , what are these pls. maybe ones firewire.
    can u confirm that u are not recommending fire-wire only because its faster
    the instructions say the following: [just so u know where im coming from]
    its strange but the instructions dont make any mention of the word firewire,[anywhere] any idea why this is
    Transferring Video Recordings to a
    Computer
    You can transfer recordings to a computer using the IEEE1394 (DV) terminal.
    You can also use this camcorder to transfer through it recordings from an analog VCR or
    8 mm camcorder to your computer using the USB terminal (see Converting Analog
    Signals into Digital Signals ( 92)).
    Before starting the video transferring, make sure to prepare the following:
    A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing
    board.
    thanks
  4. Banned
    New York, US
    IEEE1394 is Firewire.
  5. yeah i can see ur trying to help but now we are talking "standard set top DVD or BluRay" and other stuff....are u saying i have to buy them or what cause i kniow nothing about them.....i will bin the cam before i start buying huge amounts of new stuff
    still hoping to get some light on my original questions . especially "can u confirm that u are not recommending fire-wire only because its faster"
    thanks
    Oct 2005
    666th portal
    firewire is all that works for getting video off a tape using that cam. firewire cards run 10-20 bucks plus a cable. you need to know what type of slot you have open on your motherboard. pci or pci-e to pick the right type.
  7. Originally Posted by qaz112 View Post
    thanks
    You must have missed the very first reply to your post. Look again at #2.
  8. Originally Posted by qaz112 View Post
    thanks
    thanks , i may have on another pc.
    so do u think the instructions were just meaning to transfer low quality video [sort of hard to believe they wouldnt say] as was earlier suggested here [i posted them above]
    Aug 2006
    thanks
    Firewire (IEEE1394) is the standard means of transferring video from a DV camera to a PC. Not only that, but there are instructions in your camera's manual on how to use the DV port to transfer video, and no instructions in the manual for transferring video of any quality via USB.
    The only instructions I found in the camera's manual that relate to the USB connection (marked with a three-pronged symbol), indicate it is used to transfer still images to a PC or to print still images.
    The section of the manual quoted above refers to analog to digital conversion using the camera, and the reference to the USB port appears to be a mistake. If you read pages 92 and 93, it clearly states that the DV port is used to supply DV output to a PC. There is absolutely no mention of the USB port anywhere in that section of the manual.
    [Edit]The only way to copy video from a DV camera to a PC via USB is to record the analog output from the camera's composite video and analog stereo connections with a USB PC capture device while the camera is playing a tape. However, this is only recommended as a last resort for those who only have a computer that cannot accept an add-on Firewire card. DV transfer will be better quality, simpler, and no more expensive. A decent USB capture device won't cost less than a Firewire add-on card
    Last edited by usually_quiet; 23rd Feb 2014 at 11:45. Reason: grammar & add more info to post
  10. apologies i misread it,..just had another look at page 92 and 93 it still talks about other things like 8 mm and vcr.
    anyway it them seems that i need a firewire card and a dv to firewire cable and WinDV. i accept that now. its getting clearer. thanks
    do i still need the capturing board that cannon spoke of
  11. Member Cornucopia's Avatar
    Maybe this would make it clearer:
    DV port = Firewire port = IEEE1394 port
    So your cam's dv port is what you would use. Only that. The other connector is either for AC power adapter, or remote control, or analog outs - something like that (not having seen the manual yet).
  12. Member Cornucopia's Avatar
    Cable should have come with the camera (if new purchase).
  13. "DV port = Firewire port = IEEE1394 port" so its all the same thing, the cable is called a dv cable and connects the dv port to the firewire port on pc.,..yes
    do i still also need the capturing board that cannon spoke of
  14. Yes, you need a DV port on your computer.
    board.
  15. surely u mean a firewire port....this is getting really confusing
    Aug 2006
    Yes, if you don't have a Firewire /IEEE1394 port on the PC you will need to install a Firewire /IEEE1394 add-card to transfer DV video. Firewire /IEEE1394 add-cards for a desktop PC have a PCI or PCI-e interface. You have to be able open the case to see what kind of Firewire /IEEE1394 add-on card you need and to install the card. To add firewire to a laptop, the laptop must have an ExpressCard slot, and you would buy an add-on card with an ExpressCard interface.
    If there is no way to add Firewire /IEEE1394, then your only option is analog capture. See my previous post about that.
  17. yes i need a firewire card, port, socket, whatever, but please will some one say clearly whether or not i also need a do i still need the capturing board that cannon spoke of
    or is the capture device u spoke of above the same as a capturing board and will give low quality usb transfer
  18. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you get firewire installed in your computer and a 4pin to 6pin firewire cable that's all the hardware you need.
  19. good, seems simple.
    im assuming that the capture device usually quite spoke of above the same as a capturing board
    like a : [1 DELIVERED, THAT'S CHEAP] 1M Firewire IEEE 1394a 6 Pin to 4 Pin Digital Camera Camcorder PC DV Lead Cable
    AND A FIREWIRE CARD TO Fit the board
    thanks
    Aug 2006
    good, seems simple.
    No, an USB PC capture device, which digitizes analog video and audio output from the camera is something entirely different from a Firewire/IEEE 1394 card. ...but if you can use Firewire/IEEE 1394, you do not need to use (and if you are smart, do not want to use) a USB PC capture device to get the video from your camera onto a PC.
  21. ah the final knowledge. thanks every one.
    last question: obviously this cam is a bit old using tape, but how much better quality would i get from a newer digital model. im not wanting pro quality or anything but just wondering how much the actual difference would be
  22. Member Cornucopia's Avatar
    Depends on your budget. You would have to be the judge of that.
    Some better, some worse, some same. Many better, but require better pc & software in order to maintain accurate editing. Different way of working.
  23. yes i guess its not easy to answer...we'll see...
