Every Divx film i try to convert to mpeg1 i get an error half way through saying (illegal floating point calculation order).
Does anyone know what the problem is and how to stop it!!!
Please help guys!!!!!!!!!![]()
From what I know this can occur for a number of reasons.Originally Posted by chunkmonk2000
I had the problem, and that was because of a corrupt .avi.
On the other hand, I did a quick Search in the forums on 'floating' and came up with a number of threads that you could have use of; try http://forum.vcdhelp.com/viewtopic.php?t=85660&highlight=floating for starters...
HTH"The future is no longer what it used to be" -
It means you have some bad frames in the original file.
Install DivX Antifreeze; find a link under tools and change in TMPGEnc. under Environmental settings: VFAPI plug-ins: DirectShow Multimedia File Reader priority to 1 by right clicking it and select Higher Priority
NO CUTTING REQUIRED -
I assume that this Divx file is something you downloaded? Get used to it.
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 16:09 -
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
