I've seen much software that can trim .mkv files, but it will only let me delete segments from the beginning of the end of the video. What if I want to delete something from the middle of the video? (I just want to delete intro theme that is between cold opening and actual episode). Also, if I want to do that on a large scale with tens of episodes (and all have the same exact intro theme), is there a way to automatically detect the intro and delete it for me instead of doing so manually in each file?
Solveigmm avi trimmer or avidemux. You set start and stop, delete, save a new mkv.
I don't know any automatically methods. -
And I need the process to be 100% lossless, no re-encoding. Can this software do that?
Turns out I can't do that losslessly since the key frames are in such a position I can't cut that intro theme accurately. What settings should I choose in avidemux to force frame-accurate cutting with as little quality loss as possible on a .mkv file? (it contains a [h264 high L4.0, yuv420p, 1920x1080] video track and a [AAC 48000 Hz] stereo sound track). Or maybe some other software would be better for that?
You must reencode the entire video then. Try select x264/h264 under video.
Or use an editor with smart rendering that just reencodes around the cut. I think solveigmm video splitter supports that for mkv files. -
MKV Trim video commericial but keep subtitle in SYNC
By graphics in forum EditingReplies: 8Last Post: 9th Jan 2015, 13:06 -
Cut/Trim the first few second of MKV File
By jslegers73 in forum EditingReplies: 16Last Post: 24th May 2014, 23:51 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
H.264 TS -> MKV, AviSynth+DGAVCDecode+ffmpeg, trim recording + delay audio?
By Matchay in forum Video ConversionReplies: 3Last Post: 28th Jun 2012, 06:13 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45
