  1. So, guys... Until 1 week ago I was doing my everyday encoding and it went fine, then I updated my old K-lite codec pack, to the latest one and then meGUI started making problems. I tryed re-installing the codecs, but there was no effect. After 2 days of agony and fails I decided to re-install my windows 7. I then put the newest K-Lite codec pack, installed meGUI and everything was fine, exept that meGUI can't load some plugins, that I really need to use. I tryed loading them manually - no effect.
    http://puu.sh/76qtZ.jpg
  2. Member DB83's Avatar
    Jul 2007
    Well the obvious thing is to check that you have repair.dll in the avissynth plugins folder NOT the plugins folder of meGUI
  3. I do and the problem is not only with this plugin.
  4. Member DB83's Avatar
    Jul 2007
    We have so little to work with. Just commented on the error you highlighted and the obvious since all the other plug-ins were located in a different folder.
    But it is my understanding that it matters not where the plug-ins are located as long as the script has the correct path.
    But just a thought. Is this 64 bit avisynth and the actual plug-in is 32 bit.
