Did anyone test this libde265 decoder?
Libde265 has been integrated into these applications:
gstreamer plugin, source, binary packages.
Windows DirectShow filters, https://github.com/strukturag/LAVFilters/releases
ffmpeg fork, https://github.com/farindk/ffmpeg
Features:
Implemented decoding of P-slices.
Implemented decoding of B-slices.
WPP based multithreading
Parallel tiles decoding
Weighted prediction support
Results 1 to 10 of 10
Not sure what to do with most of the files I downloaded. I thought they were autobuilds but they do nothing. No clear instructions for what to do with them. The only thing I did install the libde265-filters which came with an installer.
I was able to open and play HEVC mkv and divx in WMP and MPC. Strange that MPC will play them but MPC-HC (or MPC-BE) won't. It's just as well I guess since MPC-HC has become so bloated. -
MPC-HC 1.7.3 plays this HEVC-in-MKV just fine with internal LAVFilters. So you say it can't use libde265 as DirectShow decoder? Maybe they compete with also installed LAVFilters (they seem to be a fork of these, with just an additional decoder). I doubt I would install them on any but a virtual test machine for now, as long as I am satisfied with LAVFilters...
Maybe stupid question, but when I downloaded the LAVFilters and installed them trough the provide .exe file
I noticed that there are DLL files for IntelQuickSyncDecoder, I assume this is not a decoder that decodes HEVC ?
And did anyone got this to work? -
Used by the player MPC-BE to play HEVC-10bit, and I notice the different images when using 'internal FFMPEG' and external 'LAV filter' through output MadVR (for better picture quality / settings for themselves > example)
Who is false? (it seems that ffmpeg does not look exactly from the original) -
Gravitator --- then please report the problem @ http://code.google.com/p/lavfilters/issues/list .
(Yes, I could reproduce that issue in Graphstudio --- or at least I think so
You know, nevcairiel is not a Videohelp habitué. -
And before you shoot your own foot: Only one player is able to use the Hardware Overlay (which has distinct luma/chroma settings), all other instances of video players need to use a desktop related renderer. So if you want to compare two videos running in parallel, ensure that no player is trying to use the Hardware Overlay renderer.
sos hevc
By maria kalatha in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2013, 20:56 -
theX.265 (a free HEVC) codec. Have you ever tried that HEVC encoder? (HELP)
By Stears555 in forum Video ConversionReplies: 41Last Post: 16th Sep 2013, 11:15 -
HEVC x265 Decoder
By enim in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2013, 12:58 -
Divx HEVC Decoder released
By deadrats in forum Latest Video NewsReplies: 19Last Post: 14th Jul 2013, 16:42 -
HEVC Decoder
By fid07 in forum ProgrammingReplies: 1Last Post: 17th Jan 2013, 03:56
