to a smaller size AVI, MP4 or MKV. Which programms and settings shouls I use? What system do I need so it will be able to do it? I am newbie so any help appreciated!
These files are BRRips...
Vidcoder, add video, click settings, under the video tab set the target size file size. Encode.
You can also use handbrake, tencoder, freemake video converter...but you might not be able to set the desired output file size but then adjust the bitrate, bitrate * running time = file size.
But BRRips...I hope you have ripped them yourself.
So I started and I can't understand from where I can change at VidCoder the chroma_qp_offset?
Should I change lookahead_threads from 1 to 2? I have i7 950 @ 3.06.Last edited by Balema; 22nd Feb 2014 at 02:53.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
Plain English Guide to MP4Box and Repacking MKV-MP4, MP4-MP4 (M4V).
By raregrit in forum Video ConversionReplies: 3Last Post: 8th Jul 2013, 13:52 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MTS source - need to deinterlace, resize, encode h264 and make MKV or MP4.
By ibobak in forum Video ConversionReplies: 4Last Post: 25th Jun 2012, 12:59
