hello everybody,
i'm trying to capture screens from a bluray's menu (with the play/options/extras buttons included), and im using ArcSoft TotalMedia Theatre 6.5 to capture, but what really capture is only the background image and misses the buttons/texts.
is there any way to capture the image like the way i see? with the buttons and text included?
thanks
Results 1 to 9 of 9
OK, I'll bite...How do you expect to capture the full use of buttons that are just a 'picture' on your computer captured by your capture program?
Extraordinary claims require extraordinary evidence -Carl Sagan -
Could always use Ctrl-Alt-Print Screen to copy the current window. It'll be a bitmap capture but you can then paste into MS Paint or anything else to save as a jpeg or any other format.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
There are many overlay setups where ctl+alt+prtscrn will not work. Changing the renderer might fix it, but I couldn't guarantee that.
Scott -
and he wants the play/options/extras buttons included so that he can click on them. Can't happen on a screen capture.
He probably want to use the image for reference to edit/make a new menu.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
OK poster Corrie...why do you want the buttons?
I'm not seeing where they want to use the buttons, just capture the screen. Snipping tool?
Have a good one,
neomaine
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 07:03 -
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 3rd Apr 2012, 00:54 -
How to get text from a BluRay Rip
By iamkatpeeler in forum Newbie / General discussionsReplies: 20Last Post: 25th Feb 2011, 09:12 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Active Buttons on DVD Menu
By dartmanx in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2009, 05:53
