i copied my avi video files from my camera to my computer. but when I play the videos they all freeze about a second or two into it but the sounds keeps working. I tried to use divfix and divfix++ but they didnt work, they just cut out pretty much the whole video. I tried to use virtualdub but I was so lost about how to use the program. Any suggestions? help would be friggin great cause these are home movies of my daughter.
Sounds like they are just mainly sound with no video after a couple seconds,not anything you can do,can you still play the files on your camera?
the camera is a vivitar dvr 840xhd. and the videos do work on the camera, just not after i've copied them to the computer. and under properties, it says the files are avi files. im using vlc media player as well. I even tried divx and it did the same thing as vlc. and wmp didn't play it all.
Try running a sample file through MP4Cam2AVI.
The files play via quicktime and wmp
Ive had a few vivitar camera's in the past.
Mencoder stopped working during converting from mkv to avi
By Eddy777 in forum Video ConversionReplies: 3Last Post: 23rd Aug 2012, 06:43 -
.avi movies freeze when video is saturated
By HartsVideo in forum Software PlayingReplies: 21Last Post: 9th Dec 2010, 13:34 -
Not working Windows ffmpeg -i MVI_3781.AVI main.mp4
By lindylex in forum Video ConversionReplies: 7Last Post: 3rd Jun 2010, 13:50 -
.AVI Not Working on Digital Photo Frame
By chr150 in forum Video ConversionReplies: 1Last Post: 19th Mar 2010, 22:49 -
Stubborn AVI files arent working!
By miiitchhh in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2009, 22:11
