If you have a movie that's too long for one CD is it better to cut the .avi or the .mpg file?
Is there a difference (quality, difficulty of editing, ...) at all?
It depends
. Cutting a mpg with e.g. TmpgEnc isn't frame accurate. That is the cut might not happen exactly wher you want it to be (but ist's just a couple of frames). If you have varable framerate you might have to fit the movie. When cutting with BBMpeg you can't specify where the cut should be.
Leaves you with M2-Edit but I've heard that it doesn't do a good job if you have variable frame rate.
Avi's on the other hand are usually some divx codec which means that you can onlyl cut at B-Frames (which means not frame accurate
So it's up to you...
/Miko -
Cut the AVI with Vdub, you get to find out if it has bad frames at the same time (Scan) . Most people have a few seconds of disk 1, on disk 2
1, load AVI
2, Video > scan video for stream errors
3, Select Video/audio streaming
4, save as, save out a new movie
5, load in new movie and save part1, part2 with range select at keyframes
Now use TMPGEnc -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 13:51 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 14:38 -
Want to capture Right side of Split-Screen mpg clip from Woodstock movie.
By quark258 in forum Newbie / General discussionsReplies: 15Last Post: 19th Oct 2007, 06:12 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
