My script the just loading and trimming Vid1 over and over. Thanks for the help.
LoadPlugin("E:\ffms2\ffms2.dll")
Vid1=DirectShowSource("C:\2014sd\1.mp4")
Vid2=DirectShowSource("C:\2014sd\2.mp4")
Vid3=DirectShowSource("C:\2014sd\3.mp4")
Vid4=DirectShowSource("C:\2014sd\4.mp4")
Vid5=DirectShowSource("C:\2014sd\5.mp4")
Vid6=DirectShowSource("C:\2014sd\6.mp4")
Vid7=DirectShowSource("C:\2014sd\7.mp4")
Aud1=FFAudioSource("C:\2014sd\1.mp4")
Aud2=FFAudioSource("C:\2014sd\2.mp4")
Aud3=FFAudioSource("C:\2014sd\3.mp4")
Aud4=FFAudioSource("C:\2014sd\4.mp4")
Aud5=FFAudioSource("C:\2014sd\5.mp4")
Aud6=FFAudioSource("C:\2014sd\6.mp4")
Aud7=FFAudioSource("C:\2014sd\7.mp4")
AV1 = AudioDub(Vid1,Aud1)
AV2 = AudioDub(Vid2,Aud2)
AV3 = AudioDub(Vid3,Aud3)
AV4 = AudioDub(Vid4,Aud4)
AV5 = AudioDub(Vid5,Aud5)
AV6 = AudioDub(Vid6,Aud6)
AV7 = AudioDub(Vid7,Aud7)
AV1++AV2++AV3++AV4++AV5++AV6++AV7
Crop(0,0,0,-72)
BicubicResize(1280,648,0,0)
Vid1 = Trim(18978,70586)
Vid2 = Trim(7137,42154)
Vid3 = Trim(5776,49625)
Vid4 = Trim(8430,43872)
Vid5 = Trim(7082,16808)
Vid6 = Trim(5086,27747)
Vid7 = Trim(9074,46257)
AlignedSplice(Vid1,Vid2,Vid3,Vid4,Vid5,Vid6,Vid7)
Results 1 to 11 of 11
I'm guessing it's getting implict "last" mixed up
You should explicity say which video is being trimmed for Vid1 = Trim , Vid2 = Trim, etc...
I would avoid DirectShowSource() when using Trim, as frame numbers can get mixed up (not necessarily frame accurate) . Why not use FFVideoSource() ? Since you're using FFAudioSource() for audio . You might have to use AssumeFPS(), because ffms2 sometimes gets the frame rate slightly off
There is a wrapper function in the ffms2.avsi called FFMpegSource2, which does the audiodub() for you
eg. this would use FFAudioSource, FFVideoSource, and AudioDub() in 1 step:
Vid1 = FFMpegSource2("C:\2014sd\1.mp4", atrack=-1) -
Separating the trims with commas didn't work. I also tried "++". I am not able to use FFVideoSource for some reason with my captured file but I am able to use it with videos I have already shrunk with Handbrake. Here is the media info of the mp4 that FFVideoSource will not open
General
Complete name : C:\2014sd\1.mp4
Format : MPEG-4
Codec ID : M4V
File size : 3.00 GiB
Duration : 19mn 50s
Overall bit rate : 21.6 Mbps
Movie name : My Great Capture
Description : Description here.
Recorded date : 2014-02-09
Encoded date : UTC 2014-02-09 08:46:17
Tagged date : UTC 2014-02-09 08:46:17
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Duration : 19mn 50s
Duration_LastFrame : 32ms
Bit rate mode : Variable
Bit rate : 21.4 Mbps
Maximum bit rate : 30.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.387
Stream size : 2.96 GiB (99%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 19mn 50s
Bit rate mode : Constant
Bit rate : 216 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 31.4 MiB (1%)
Language : English
Tagged date : UTC 2014-02-09 08:46:17 -
If you're using directshowsource() for the video, why not use it for the audio as well ?
Sorry I wasn't clear enough - I didn't mean separate them by commas . Use a name reference, instead of implicit "last"
eg. If you meant to cut from the 1280x648 appended video , give it a name like "resized".
(or did you mean to cut from each individual video - what numbers do your trim numbers reference to) ?
Code:AV1++AV2++AV3++AV4++AV5++AV6++AV7 Crop(0,0,0,-72) BicubicResize(1280,648,0,0) resized=last Vid1 = resized.Trim(18978,70586) Vid2 = resized.Trim(7137,42154) Vid3 = resized.Trim(5776,49625) Vid4 = resized.Trim(8430,43872) Vid5 = resized.Trim(7082,16808) Vid6 = resized.Trim(5086,27747) Vid7 = resized.Trim(9074,46257) AlignedSplice(Vid1,Vid2,Vid3,Vid4,Vid5,Vid6,Vid7)
I was able to use to use FFIndex and load my captured video. How do I load multiple sources with it? Also how do I trim each source.
FFIndex("C:\2014sd\1.mp4")
A = FFAudioSource("C:\2014sd\1.mp4")
V = FFVideoSource("C:\2014sd\1.mp4")
AudioDub(V, A)
Crop(0,0,0,-72)
BicubicResize(1280,648,0,0) -
You shouldn't need to use FFIndex, it's automatically called by FFVideoSource and FFAudioSource or FFMpegSource2
Use better names and variables. Give them each names to keep it organized
To trim individual videos, use Trim immediately after you call the video (so implicit last is used), or explicitly use the variable name of the video before trim.
Code:A1 = FFAudioSource("C:\2014sd\1.mp4") V1 = FFVideoSource("C:\2014sd\1.mp4") AudioDub(V1, A1) Crop(0,0,0,-72) BicubicResize(1280,648,0,0) Vid1=last A2 = FFAudioSource("C:\2014sd\2.mp4") V2 = FFVideoSource("C:\2014sd\2.mp4") AudioDub(V2, A2) Crop(0,0,0,-72) BicubicResize(1280,648,0,0) Vid2=last Vid1.Trim(100,200) ++ Vid2.Trim(500,600)
In this example, Vid1 is trimmed from 100 to 200 , and appended to Vid 2 which was trimmed from 500 to 600. The trim numbers reference to the original video frame numbers from Vid1, Vid2 , respectivelyLast edited by poisondeathray; 14th Feb 2014 at 09:59.
Yes the preview is fine in Windows Media Player and the preview that pops up for MeGUI.
-[Error] Log for job14 (video, Copy_megui_otherx264_2.avs -> Copy_megui_otherx264_2_1.264)
--[Information] [2/14/2014 11:21:56 AM] Started handling job
--[Information] [2/14/2014 11:21:56 AM] Preprocessing
--[Information] [2/14/2014 11:21:56 AM] Avisynth input script
---[NoImage] LoadPlugin("C:\Users\lguser\Documents\MeGUI_2418_x 86\tools\ffms\ffms2.dll")
---[NoImage] A1 = FFAudioSource("C:\Users\lguser\Documents\Downloads \Trey Canard REvival 41 Official Movie temp files\9.mp4")
---[NoImage] V1 = FFVideoSource("C:\Users\lguser\Documents\Downloads \Trey Canard REvival 41 Official Movie temp files\9.mp4")
---[NoImage] AudioDub(V1, A1)
---[NoImage] Crop(0,0,0,-72)
---[NoImage] BicubicResize(1280,648,0,0)
---[NoImage] Vid1=last
---[NoImage] A2 = FFAudioSource("C:\Users\lguser\Documents\Downloads \Trey Canard REvival 41 Official Movie temp files\10.mp4")
---[NoImage] V2 = FFVideoSource("C:\Users\lguser\Documents\Downloads \Trey Canard REvival 41 Official Movie temp files\10.mp4")
---[NoImage] AudioDub(V2, A2)
---[NoImage] Vid2=last
---[NoImage] Vid1.Trim(0,600) ++ Vid2.Trim(0,600)
--[Information] [2/14/2014 11:21:57 AM] resolution: 1280x648
--[Information] [2/14/2014 11:21:57 AM] frame rate: 60001/1001
--[Information] [2/14/2014 11:21:57 AM] aspect ratio: 160:81 (1.975)
--[Information] [2/14/2014 11:21:57 AM] Job commandline: "C:\Users\lguser\Documents\MeGUI_2418_x86\tools\x2 64\x264.exe" --level 4.0 --preset slow --pass 2 --bitrate 3333 --stats "C:\Users\lguser\Documents\Downloads\Trey Canard REvival 41 Official Movie temp files\Copy_megui_otherx264_2_1.stats" --keyint 599 --vbv-bufsize 31250 --vbv-maxrate 25000 --merange 32 --subme 10 --trellis 2 --sar 1:1 --output "C:\Users\lguser\Documents\Downloads\Trey Canard REvival 41 Official Movie temp files\Copy_megui_otherx264_2_1.264" "C:\Users\lguser\Documents\Downloads\Trey Canard REvival 41 Official Movie temp files\Copy_megui_otherx264_2.avs"
--[Information] [2/14/2014 11:21:57 AM] Process started
--[Information] [2/14/2014 11:21:57 AM] Standard output stream
--[Error] [2/14/2014 11:21:57 AM] Standard error stream
---[Information] [2/14/2014 11:21:57 AM] avs [info]: 1280x648p 1:1 @ 60001/1001 fps (cfr)
---[Information] [2/14/2014 11:21:57 AM] x264 [info]: using SAR=1/1
---[Information] [2/14/2014 11:21:57 AM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Error] [2/14/2014 11:21:57 AM] x264 [error]: ratecontrol_init: can't open stats file
---[Error] [2/14/2014 11:21:57 AM] x264 [error]: x264_encoder_open failed
--[Error] [2/14/2014 11:21:57 AM] Process exits with error: 0xFFFFFFFF (-1)
--[Information] [2/14/2014 11:21:57 AM] Job completed -
Where is the 1st pass log? (Did you run the 1st pass?)
Try encoding in CRF mode, to see if it actually encodes anything, this will help rule out other issues -
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30 -
avisynth subtitle script problem
By dj-big in forum SubtitleReplies: 0Last Post: 20th Dec 2012, 00:49 -
Avisynth Script Help - Trimming and Joining
By Legiit in forum EditingReplies: 1Last Post: 1st Mar 2012, 12:30 -
Trimming with Avisynth: An exploration
By Krelmaneck in forum EditingReplies: 2Last Post: 22nd Oct 2010, 12:20 -
AviSynth Script Problem
By Eva-Unit01 in forum EditingReplies: 21Last Post: 29th Dec 2009, 12:00
