I use Xmedia Recode(for fixing compatibility via A/V recode) and multiAVCHD for Blu-Ray Authoring as back ups. Also, ImgBurn for burning Blu-Ray video discs. Many a times there is considerable free space that gets wasted. Around 2gb and sometimes even 4gb.
I would like to fill these spaces with my iTunes/ Netflix HD downloads.
But, I do not wish to do any kind of Audio or Video re-encoding with these files to add them to the compilation.
Rather, I would like to burn these files separately with my compilation as Digital Copies. I have heard of movie titles being released as Blu-Ray combo with Digital Copy.
Is this even possible on a single disc without affecting Blu-Ray video playback? Or is it a long shot?
Please let me know my options. Thanks in advance.
Yes. You can put data files on a blu-ray video disc. Just put them outside the BDMV folder.
Thanks. I was aware of this.
What I wanted to know whether standalone Blu-ray players will be able to show/play these non Blu-ray video files.
My Sony Blu-ray player can play media files like mkv, mp4, avi, ts, m2ts etc. from usb drives and data discs like BD-R/RW, DVD-R/RW etc.
Is it possible to make a part Blu-ray video and part data disc?
Is there a specific burning software and/or method? -
I haven't seen any special method for that. So it's probably up to each bluray player if you can browse for data files on a bluray video disc.
This is great. I only added the non Blu-Ray video file in an extra folder and the BD player menu showed the burned disc as 2 discs. One as a BD-R BDMV and the other a Data BD.
I was able to play both without any issue. Wow!
I hope this feature remains in future BD players. -
As Baldrick said, this is totally dependent upon the capabilities of the firmware in the player.
Also, most players that I've checked DO NOT support multi-session and/or multi-mode (if you were thinking of trying one of those burning options), and many players that I've checked follow a much more simplistic method of determining the playable format on the media. Some check media type first, some check application folder/file structure existence first. Many of those will pick the FIRST playable format, NOT list all available formats.
I'd say you just lucked out this time.
Are Blu-ray/VHS combo devices made anymore?
By agent154 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 13th Sep 2013, 22:22 -
Region Free HD-DVD Blu-ray combo player
By Daniel_BMS in forum DVD & Blu-ray PlayersReplies: 14Last Post: 29th Jun 2012, 00:03 -
Creating a Blu-Ray from TV Shows
By dbanimal in forum Video ConversionReplies: 10Last Post: 23rd Feb 2011, 14:31 -
Combo enclosure for blu-ray burner and HD
By sharjohn in forum DVD & Blu-ray WritersReplies: 1Last Post: 20th Nov 2010, 05:09 -
Creating Blu-ray from HD .MOV files
By Art King in forum Authoring (Blu-ray)Replies: 1Last Post: 25th May 2010, 16:17
