Before opening this new thread i did a bit of research through old ones. Found some useful info, but still doubtful about this and that, hence opening a new one.
This is the thing: I live in Europe (region 2, PAL) and need to burn a couple of movies for my friend living in USA.
My stand alone DVD is not hacked or anything, but I can flawlessly play NTSC dvds on it as long as they are "all regions" and not region 1.
My question is: if i simply turn my movies from PAL Region 2 to PAL all region, will she be able to play them on her standalone dvd in the USA? I guess that depends on what model of dvd player she has, but I would like to know if chances are possibly high or not. I would reencode them in NTSC only if really needed.
Thanks in advance for your time to read this and for any kind of hints or suggestions.
Probably not.
I'd say the chances are under 10%. Most 'regular' people don't search out a player that can convert PAL to NTSC and as a rule NTSC DVD players can't play PAL DVDs. You could always ask her the brand and model of the player and then ask or check the database here. If it's to be a surprise I wouldn't chance it....but I would like to know if chances are possibly high or not. -
Thank you Manono, I think I'll go for a full reencode then, just to be sure. Any suggestions on which software will do better?
I usually work with Dvd Decrypter and DVD-Lab Pro 2, but i use them to avoid reencoding. -
If you are really only doing this twice, fine, but if you are really going to be doing this all the time, you'd be better off to just buy your friend a converting DVD player. Philips still makes converting DVD (NOT BluRay) players in the USA and Canada.
Women are rarely as interested in video as men are. I suggest you consider the possibility that the only person who really wants to see these videos is YOU and not her. Don't put yourself to a lot of trouble because the odds are that she probably doesn't care about seeing them as much you think she does or as much as you want her to see them. I speak from experience here.
HTPC to play Region 2 PAL DVD on NTSC HDTV
By Mike99 in forum Software PlayingReplies: 12Last Post: 5th Jul 2012, 23:34 -
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 05:35 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 10:28 -
Region Free/ Ntsc PAL Compatible
By veryconfused in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Nov 2009, 19:53
