like to make a preset for handbrake using the xml exported from mediainfo GUI just dont know how or if there is a converter for the xml.
heres a mp4 file mediainfo xml like to convert to preset in handbrake.
<?xml version="1.0" encoding="UTF-8"?>
<Mediainfo version="0.7.67">
<File>
<track type="General">
<CompleteName>The bang theory.mp4</CompleteName>
<Format>MPEG-4</Format>
<Format_Profile>Base Media</Format_Profile>
<CodecID>isom</CodecID>
<FileSize_String>172 MiB</FileSize_String>
<Duration_String>21mn 35s</Duration_String>
<OverallBitRate_Mode_String>Variable</OverallBitRate_Mode_String>
<OverallBitRate_String>1 112 Kbps</OverallBitRate_String>
<Encoded_Date>UTC 2013-09-26 16:45:10</Encoded_Date>
<Tagged_Date>UTC 2013-09-26 16:45:10</Tagged_Date>
</track>
<track type="Video">
<ID_String>1</ID_String>
<Format>AVC</Format>
<Format_Info>Advanced Video Codec</Format_Info>
<Format_Profile>High@L3.1</Format_Profile>
<Format_Settings_CABAC_String>Yes</Format_Settings_CABAC_String>
<Format_Settings_RefFrames_String>5 frames</Format_Settings_RefFrames_String>
<CodecID>avc1</CodecID>
<CodecID_Info>Advanced Video Coding</CodecID_Info>
<BitRate_String>989 Kbps</BitRate_String>
<BitRate_Maximum_String>8 839 Kbps</BitRate_Maximum_String>
<Width_String>720 pixels</Width_String>
<Height_String>404 pixels</Height_String>
<DisplayAspectRatio_String>16:9</DisplayAspectRatio_String>
<FrameRate_Mode_String>Constant</FrameRate_Mode_String>
<FrameRate_String>23.976 fps</FrameRate_String>
<ColorSpace>YUV</ColorSpace>
<ChromaSubsampling>4:2:0</ChromaSubsampling>
<BitDepth_String>8 bits</BitDepth_String>
<ScanType_String>Progressive</ScanType_String>
<Bits_Pixel_Frame_>0.142</Bits_Pixel_Frame_>
<StreamSize_String>153 MiB (89%)</StreamSize_String>
<Encoded_Library_String>x264 core 138 r2358 9e941d1</Encoded_Library_String>
<Encoded_Library_Settings>cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00</Encoded_Library_Settings>
<Encoded_Date>UTC 2013-09-26 16:39:13</Encoded_Date>
<matrix_coefficients>BT.709</matrix_coefficients>
</track>
<track type="Audio">
<ID_String>2</ID_String>
<Format>AAC</Format>
<Format_Info>Advanced Audio Codec</Format_Info>
<Format_Profile>LC</Format_Profile>
<CodecID>40</CodecID>
<Duration_String>21mn 34s</Duration_String>
<BitRate_Mode_String>Variable</BitRate_Mode_String>
<BitRate_String>119 Kbps</BitRate_String>
<BitRate_Maximum_String>158 Kbps</BitRate_Maximum_String>
<Channel_s__String>2 channels</Channel_s__String>
<ChannelPositions>Front: L R</ChannelPositions>
<SamplingRate_String>48.0 KHz</SamplingRate_String>
<Compression_Mode_String>Lossy</Compression_Mode_String>
<StreamSize_String>18.3 MiB (11%)</StreamSize_String>
</track>
</File>
</Mediainfo>
Please Help.![]()
No converter.
The only method I know of is to use Mis2x264 to copy most x264 encoding settings and use them in the x264 encoder. But I don't know how to use it in handbrake. -
thanks for your reply Baldrick,
how do i use x264 to DVD rip (D:\VIDEO_TS\) with the encoding settings applied? cant seem to figure that one out.
heres
Converted to x264 cli:
--cabac --ref 5 --deblock 1:1 --partitions all --me umh --subme 9 --psy-rd 1.00:0.00 --merange 16 --trellis 2 --8x8dct --cqm flat --deadzone-inter 21 --deadzone-intra 11 --chroma-qp-offset -2 --threads 18 --lookahead-threads 1 --bframes 3 --b-pyramid normal --b-adapt 2 --b-bias 0 --direct auto --weightp 2 --keyint 250 --min-keyint 23 --scenecut 40 --rc-lookahead 60 --crf 20.0 --qcomp 0.60 --qpmin 0 --qpmax 69 --qpstep 4 --ipratio 1.40
.mp4 & .m4v Files Unreadable Suddenly (VLC, MPLAYERX, HandBrake, MediaInfo)
By jmix93 in forum Video ConversionReplies: 4Last Post: 30th Oct 2013, 12:00 -
Customize/hack a Adobe export preset?
By Gobblor in forum Video ConversionReplies: 2Last Post: 17th May 2012, 03:11 -
Why doesn't handbrake re-encode show video bitrate in MediaInfo?
By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 16:55 -
Mediainfo Export Files Appear Scrambled
By zoomie in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2012, 15:33 -
Handbrake Preset Confusion
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2011, 01:38
