I have several files mp4 and i must merge them. What software can i use to do it easily?
I tried mp4joiner but don't work well!
Results 1 to 11 of 11
Try mymp4boxgui. Under join add all mp4s and join.
You can also try video to video converter(under tools), boilsoft video joiner(trial).
But it may fail if the mp4s files have different properties. You must then reconvert, use for example freemake video converter(adware!), add all mp4s and under top right click join. Convert to a new mp4. -
Hi all,
I recently found a program MP4Joiner (http://www.mp4joiner.org/en/) that seems to work quite well. I've only had one case where it didn't seem to join two files together and I suspect that was operator error.
rcubed -
what are the conditions? The impact of the resolution, codec? Browse for some labels
Baldrick,
Thanks,
I forgot to mention the Adware part. I'm used to reading the install screens (very carefully) and trying to deselect all the "goodies" that seem to be included.
For some reason when I tried to use MY MP4 Box GUI I had problems trying to get the program to put the output where I wanted it. Probably teaching old dog new tricks problem.
Will have to investigate further.
rcubed -
Same goes for MpegStreamClip, works great on 4k material too.
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 16th Nov 2023, 00:16 -
Join multiple MP4 HD Files from Rooster Teeth
By Simmons in forum EditingReplies: 3Last Post: 26th Jun 2012, 14:52 -
join sveral mp4 files one after the other
By erelir in forum EditingReplies: 4Last Post: 5th Aug 2011, 06:18 -
PLEASE HELP ME - Join many MP4 files from youtube
By jamfeb1 in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2011, 16:22 -
Avidemux + YAMB couldn't join my .mp4 files - help!
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 14th Jan 2010, 16:33
