I have an M4V file and it has an AAC 2 channel stereo and AC-3 6 channel surround audio tracks. I want to select the AC-3 audio track for my final AVI output file. How do I select this audio stream in VirtualDub? I have the latest version VirtualDub, version 1.10.4. I tried VirtualDubMod, but that doesn't support MP4/M4V video files. Yes, I installed the plugins for both the MP4 and AC-3 files in the "Plugins" folder in VirtualDub.
Give mymp4boxgui a try, or mkvtoolnix/mkvmerge for an MKV file.
https://www.videohelp.com/tools/My-MP4Box-GUI
https://www.videohelp.com/tools/MKVtoolnix -
You should be able to select the audio track in vdub by audio=> source audio => (choose stream 1 or 2)
But some input plugins might only allow you to access track 1, so it depends on how you have it configured -
Demux the AC3 stream from the M4V file with MP4Muxer (or ffmpeg, or whatever). Then add the AC3 file to VirtualDub with Audio -> Audio From Another File.
VirtualDub
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2013, 16:58 -
Virtualdub Virtualdub Mod Prism All doubling file sizes durning compression
By 36boomer in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2013, 14:39 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 16:00
