1. If I convert from 6 channels to 2 channel stereo audio, will I hear "surround sound" in both ears, or is all the audio (sound effects, dialogue, soundtrack) from the 6 channels being combined into both the 2 channels?
2. Also, if my audio is already compressed in either AAC 2 channel stereo and/or AC-3 6 channel surround, and I choose "Uncompressed PCM" as my audio codec for output and then when the audio is re-encoded again into Dolby Digital Recording, in Windows DVD Maker, am I hearing the original "Compressed" audio (AAC/AC-3) or "Uncompressed PCM" audio (No Compression in VirtualDub AVI output) when the burned DVD-video disc is being played back in a DVD player connected to a TV?
Edit: I forgot to add these links I found on what audio technology that Windows DVD Maker uses to encode audio information for DVD's:
http://www.experts123.com/q/what-technology-does-windows-dvd-maker-use-to-encode-audio...-for-dvds.html
http://www.theithelpdesk.co/cd-dvd-and-optical-drive-issues-how-to-burn-a-dvd-video-di...rmation-to-it/
Last edited by JackSpicer0; 6th Feb 2014 at 23:14. Reason: Forgot to add for information to post/thread
You will lose all the sound effects and have just stereo sound.
It depends on how the conversion is done. Some programs will simply toss the extra channels. Some will use phasing and equalizing tricks to simulate surround sound. For example, listen to the Virtual Barbershop demo (with headphones):
http://qsound.com/demos/virtualbarbershop_long.htm
Note, that's not a 6 channel to 2 channel conversion, just a demonstration that you can create fairly convincing surround effects with only two channels.
You're hearing the earlier compressed AAC or AC3 audio. Think of it this way: playing a compressed audio source involves first decompressing it to uncompressed PCM, then sending the uncompressed PCM to the card. So the fact that you're decompressing the audio to uncompressed PCM and saving it that way is no different than what happens when you simply play the original AAC/AC3 audio.Last edited by jagabo; 7th Feb 2014 at 12:37.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
converting 6 channel audio to 2 channel & putting 2 streams in a container
By qorda in forum AudioReplies: 3Last Post: 14th Jan 2014, 02:43 -
Converting 6 channel audio to 2 channel stereo- Help needed
By drashkum in forum AudioReplies: 2Last Post: 7th Sep 2013, 22:33 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46
