Trying to display a jpeg image and add an mp3.
Cheers from downunder.
Previously posted...https://forum.videohelp.com/threads/355301-Merging-an-image-in-audio-file/page2
YOU can find previous versions of FFMpeg at http://ffmpeg.zeranoe.com/builds
If ypou have FFMpeg version 04262012 install you can use:
CONVERT SINGLE IMAGE WITH AUDIO STREAM
Simple 1X1 method:
ffmpeg -loop 1 -r 1 -shortest -qscale 1 -i "pix2.jpg" -i "1.mp4" -acodec copy -vcodec mpeg4 "output.mp4"
ffmpeg -loop 1 -r 1 -shortest -qscale 1 -i "C:\path to\image.jpg" -i "C:\path to\audio.mp3" -acodec copy -vcodec libx264 "output.flv"
With more current versions you can use below But I do not recommend it since it takes longer and the -shortest doesn't end when the audio stops.:
ffmpeg -loop 1 -i "C:\path to\image.jpg" -i "C:\path to\audio.mp3" -loop 1 -r 1 -qscale 1 -shortest -acodec copy -vcodec libx264 "output.flv"
Batch: (04262012 again)
Type the following, replacing the word Herringbone with the name of your image <for avi output>
for %a in (*.mp3) do ffmpeg -loop 1 -r 1 -shortest -i " Herringbone.jpg " -i "%a" -acodec copy "%~na.avi"
In the example below, replace the word Herringbone with the name of your image <for mp4 output>
for %a in (*.mp3) do "ffmpeg" -loop 1 -r 1 -shortest -i "Herringbone.jpg" -vcodec mpeg4 -i %a -acodec copy %a".mp4"
Or type the following, replacing the word Herringbone with the name of your image <for flv output>
for %a in (*.mp3) do "ffmpeg" -loop 1 -r 1 -shortest -i "Herringbone.jpg" -vcodec flv -i %a -acodec copy %a".flv"
-loop 1 will loop your input image, -r 1 will give the video a fps of 1, for a smaller file size. If this causes problem for some odd reason, you can take it out. -shortest will limit the output file to the length of the input audio file.
UPDATE: Later versions work ok if you put filters AFTER the inputs and drop -r1 (more frames larger file. Lower the Q?)as:
ffmpeg -loop 1 -i "C:\path to\image.jpg" -i "C:\path to\audio.mp3" -shortest -loop 1 -qscale 1 -shortest -acodec copy -vcodec libx264 "output.flv"Last edited by Budman1; 6th Feb 2014 at 18:13. Reason: Update
Image display help on LCD TV
By David Montanaro in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2011, 12:16 -
connect pc to tv and display image on both screens
By gordes04 in forum ComputerReplies: 11Last Post: 23rd Sep 2010, 08:02 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
exporting a captured image as a JPEG file
By altagracia in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 22:59 -
how to retrive jpeg image from unfinalized DVD-r
By newtonraj in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2009, 05:42
