i am using TMPGEnc to change AVI - MPEG and have successfully created one VCD for myself... but now every other AVI i try to convert will appear with audio and just a BLACK SCREEN - no video for some reason. i know how to check if it is PAL or NTSC or NTSC film but how do i remedy this situation to get the video to come through again??? please help me out!!! :cry:
Results 1 to 9 of 9
Originally Posted by kn0wl3dge
"...or you just get a empty/black video preview window:
Be sure that you have installed the DivX Codecs(both DivX 3.11, 4 and 5)
and also try with the Nimo Codec Pack. If that does not work try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video."
Be sure to convert a little of your film, abort the conversion, and play the resultant file, because you may need to adjust the sound due to a delay with the video. Good luck. -
still wont work - i still get a black screen... and i can't download the nimo codec pack...
Your the fourth person including myself that has had this problem. what is the deal with the black screen?
Tell me about it, I get that same problem when I convert with panasonic mpeg . Its a serious downer
anyone have any ideas as to why Panasonic causes a black screen and TMPGEnc works.The Hellsing family will purify this world... -
well i fixed this bastard problem finally! using the codecs from divX 3.11 4 and 5 will allow use of older movies to be converted... and changing the priority of that plug-in "VFAPI i think" up to about 1 or 2 also fixed this little issue. and properly multiplexing your movies help that floating point error and system clock reference 1058 error too! i finally got some things done!!
So the DivX codecs 3.11 4 and 5 can all be installed seperatly in the same system ?
if thats the case I will have to get the other ones alsoThe Hellsing family will purify this world... -
Upping the DirectShow priority works! Thanks!
Have Burner will Travel -
Same here - changing the DirectShow priority fixed the black screen problems. If there's a FAQ on the subject anywhere, this fix definitely needs to go into it.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Black (blank) screen after converting MKV to BD with TSMuxer & ImgBurn
By Jijital in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Oct 2011, 07:24 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
black screen on ps3 after converting video
By unknownguy in forum Video ConversionReplies: 1Last Post: 22nd Jan 2009, 06:26 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
