Page 2 of 2
FirstFirst 1 2
Results 31 to 48 of 48
  1. Strange thing is that it didn't require greatest for me, but if it's now resolved for you that's fine.
  2. Attached a new version.
     *   Kvazaar HEVC Encoder v. 0.2.4             *
     *     Tampere University of Technology 2014   *
    Usage:
    kvazaar -i <input> -w <width> -h <height> -o <output>
    Optional parameters:
          -n, --frames <integer>     : number of frames to code [all]
          -q, --qp <integer>         : Quantization Parameter [32]
          -p, --period <integer>     : Period of intra pictures [0]
                                         0: only first picture is intra
                                         1: all pictures are intra
                                         2-N: every Nth picture is intra
          -r, --ref <integer>        : Reference frames, range 1..16 [3]
              --no-deblock           : Disable deblocking filter
              --deblock <beta:tc>    : Deblocking filter parameters
                                       beta and tc range is -6..6 [0:0]
              --no-sao               : Disable sample adaptive offset
              --aud                  : Use access unit delimiters
              --cqmfile <string>     : Custom Quantization Matrices from a file
      Video Usability Information:
              --sar <width:height>   : Specify Sample Aspect Ratio
              --overscan <string>    : Specify crop overscan setting ["undef"]
                                         - undef, show, crop
              --videoformat <string> : Specify video format ["undef"]
                                         - component, pal, ntsc, secam, mac, undef
              --range <string>       : Specify color range ["tv"]
                                         - tv, pc
              --colorprim <string>   : Specify color primaries ["undef"]
                                         - undef, bt709, bt470m, bt470bg,
                                           smpte170m, smpte240m, film, bt2020
              --transfer <string>    : Specify transfer characteristics ["undef"]
                                           smpte170m, smpte240m, linear, log100,
                                           log316, iec61966-2-4, bt1361e,
                                           iec61966-2-1, bt2020-10, bt2020-12
              --colormatrix <string> : Specify color matrix setting ["undef"]
                                         - undef, bt709, fcc, bt470bg, smpte170m,
                                           smpte240m, GBR, YCgCo, bt2020nc, bt2020c
              --chromaloc <integer>  : Specify chroma sample location (0 to 5) [0]
  3. Mp4Box muxing issues got fixed, latest Mp4Box (rev5092) can now multiplex Kvazaars output.
  4. Kvazaar - H.265 encoder - v0.2.4
    This release fixes a bunch of bugs and general usability issues. We skipped 0.2.2 and 0.2.3 because I increased the version number to 0.2.3 pre-emptively in the source, and that was a while ago. There is a small 0.5% - 1% improvement in BD-rate due to bug fixes.
    Features:
    Linked release against normal VS2010 DLLs instead of debug ones. Non-developers might not have the debug DLLs installed.
    Added long parameter support.
    And new parametsrs (--no-deblock, --deblock, --no-sao, --aud).
    And aliases for old parameters (--frames, --qp, --period).
    Added many parameters to add VUI (Video Usability Information) to the bitstream (--sar, --overscan, --videoformat, --range, --colorprim, --transfer, --colormatrix, --chromaloc).
    Improved lambda cost list resulting in more even encoding results with different QPs. Overall BD-rate remained roughly the same.
    Fixed bugs:
    Fixed several crashes.
    When QP < 15.
    When motion vectors points way outside the picture.
    Overflow during initialization that resulted in a crash on Linux.
    Fixed artifacts that sometimes happened at the bottom of intra frames.
    Fixed bug in motion vector cost estimation that resulted in long motion vectors some sequences (such as all black).
    Fixed a bug that added an extra frame at the end of the video.
    https://github.com/ultravideo/kvazaar/releases/download/v0.2.4/kvazaar_v0.2.4_windows-x86-64.zip
    https://github.com/ultravideo/kvazaar/releases/download/v0.2.4/kvazaar_v0.2.4_windows-x86.zip
    Source Code:
    https://github.com/ultravideo/kvazaar/archive/v0.2.4.zip
    Thank's SELUR
  5. to avoid confusion: the versions I uploaded are newer than the 8 day old infos Marchand quotes from: https://github.com/ultravideo/kvazaar/releases/tag/v0.2.4
    Nov 2002
    Wow! this encoder is the slowest one yet. Well, not as slow as the old strongene lentoid encoder but slow at .48 fps for a 1080p animation that multicoreware x265 encodes at over 10 fps..
  7. @DarrellS: It's an academic open source project. (Tampere University of Technology), see: http://ultravideo.cs.tut.fi/#encoder.
    So it's not surprising it's not as fast as other encoders especially since it's really new.
    Nov 2002
    Thanks! I'll try and follow it's progress as I will the other HEVC encoders.
    Nov 2002
    Looking at the finished encode, the bitrate is twice as high as the multicoreware encode. I used the ultrafast preset in the multicore encode and the quality still looked good. My source is an animation made from stills with solid background color. The multicoreware encoder seems to be coming along better than I thought. I was having to use the encoder settings that you had posted for the presets but now I am able to just use the presets on their own which helps when creating encoder sets in Virtualdub..
    EDIT: Encoded the same file with x265_ 0.4.1+546-ccac3a7d3622 and the filesize was 205 KB (900 frames at 15.85 fps) compared to 1243 KB at .48 fps.
    Hard to believe that you can get a 900 frame HEVC 1080p video from a 27,148 KB nine layer PSD file converted to a 59 MB AVI.
  10. No surprise, Kvazaar doesn't use B-Frames and other more advanced coding options atm. (see roadmap)
    Aug 2013
    China
    @Selur
    Selur can help report a BUG to kvazaar?
    SPS incomplete data streams
    Mkvmerge mux estimate truncated data
  12. If you can tell me how to reproduce the problem, I can report it.
    Aug 2013
    China
    Command Line
    avs2yuv -raw "%~dpn1.avs" -|kvazaar.exe -i - -w 848 -h 480 -q 27 -p 250 --deblock 0:0 --rd 2 -o "%~dpn1_video.hvc"
    mkvmerge GUI 64bit mux appear bug
  14. using kvazaar 0.3.0:
    mencoder -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -vf scale,format=i420 -sws 10 -forcedsubsonly -nosub -nosound -mc 0 "H:\Temp\encodingTempAvisynthSkript_21_47_10_4310.avs" | kvazaar -i - --input-res 848x466 --frames 429 --qp 27 --rd 2--period 250 --sar 1:1 -o "H:\Temp\test_21_47_10_4310_03.265"
    and using mkvmerge 6.9.1:
    mkvmerge --ui-language en -o "H:\Output\test.mkv" -d 0 --default-track 0:yes --default-duration 0:25000/1000fps --aspect-ratio-factor 0:1/1 --no-chapters --compression -1:none --forced-track 0:yes --no-audio --no-subtitles "H:\Temp\test_21_47_10_4310_03.265"
    I can't reproduce the problem.
    So doesn't look like a bug in kvazaar.
    I also just tried mmg (mkvmerge gui) and couldn't reproduce your problem either.
    Aug 2013
    China
    Build fails
    Selur
    Is there any way to solve
    With the http://xhmikosr.1f0.de/tools/msys/ of MSYS_MinGW-w64_GCC_491_x86-x64_Full.7z building
  16. you might want to look at https://github.com/jb-alvarado/media-autobuild_suite, last time I checked that script build kvazaar without a problem
  17. DECEASED
    Jun 2009
    Heaven
    Sadly, it does appear they give much more consideration to Visual Studio than to MinGW
  18. Member
    Aug 2013
    China
    Seemingly can not use WPP
