    Dec 2013
    Hello, i am having a issue with ffmpeg
    i enter a command for ts to mp4
    "C:\ffmpeg\bin\ffmpeg.exe" -i "c:\ffmpeg\Space.ts" -c:v copy -c:a ac3 -b:a 448k "c:\ffmpeg\Space.mp4"
    is there a command where i can have the bit rate as close as to the original bit rate for video?
    i get the converted video in mp4 , but the bit rate isn't the original , neither do the details of the resolution show up
    Is there a command that can fix that issue ?
    Thank you
    "-c:v copy" copies the video.
    Try compare the bitrate with mediainfo or a bitrate viewer.
  3. Depending on the ffmpeg version, once again there might just be a bug in the mp4 muxing routines of ffmpeg, in general I would recommend to use mp4box instead of ffmpeg for muxing to mp4.
    -> try if remuxing your output with mp4box files the header infos.
