If you start with progressive 29.97 video, is there anything that will interpolate in-between frames so you end up with either 59.94 progressive video or 29.97 interlaced?
I don't mean just create a duplicate of the existing frames but interpolate motion between the existing 29.97 frames and double the frame rate.
avisynth - interframe, mflowfps (mvtools2 based)
msu frc
twixtor, kronos, after effects timewarp/pixel motion, many others... -
You can find DoubleFPS2() in these forums. It uses mvtools2. And for replacing or inserting individual or short sequences of frames you can find my modifications of RX() as ReplaceFramesMC and InsertFramesMC.
But as Selur pointed out, these motion interpolating techniques don't always work well. They're great for simple panning shots. Terrible with large complex motions -- especially cartoons.
Plugin to interpolate dropouts within a frame?
By brassplyer in forum RestorationReplies: 23Last Post: 24th Dec 2013, 10:42 -
Convert fields to frames
By omepheus in forum EditingReplies: 21Last Post: 26th Dec 2012, 09:00 -
Pandora App on VIZIO LCD TV doesn't turn off when switched back to TV?
By jpersonette in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2012, 18:16 -
Any such thing as an app to turn PC into real time DVD recorder?
By brassplyer in forum DVD & Blu-ray RecordersReplies: 12Last Post: 31st Mar 2010, 21:10 -
convert fields into 50fps vertical half frames & back
By l.pandit in forum Video ConversionReplies: 3Last Post: 7th Feb 2010, 07:21
