I need help playing a movie I downloaded. I downloaded Divx 5.0 pro to see if I didn't have the right codecs and nothing seems to work. All I get is the audio of the movie and a blank screen. The file ends with a .ts.avi extension. This is really frustrating and I would appreciate any help.
i have had this problem in the past the avi file was bacially 'fucked'! there was no way of getting the avi to play the video unless someone else knows how to do it? i know how frustrating it is!
Mikey :lol: -
I downloaded VirtualDub and it worked so maybe you could try that. Apparently I didn't have the right codecs or something. All I want to do is watch a friggin' movie!!!!
I have seen this problem with downloaded files as well. VirtualDub will play just about everything so if all you are interested in is watching on your computer then VirtualDub will work. If you want to watch the film on a stand alone DVD player, then you need to convert the video to a SVCD or VCD format (MPEG2 or MPEG1). The guides on the left side of this site tell you all you need to know.
My solution is to convert the file in TMPG. You may have to go through a couple of steps depending on the format of the file you downloaded. Again using Virtual Dub, I strip off the audio into a wav file (converting to 44.1kHz from 48kHz if necessary). Then plug the original video and the new wav file into TMPG, select the VCD template (PAL, NTSC, or NTSCFilm) and push Start. After a few hours, you'll have an mpg file you can burn to VCD with VCDEasy or Nero. If the resulting file is longer than 74 minutes, you'll have to break it up into two files. You can do this in TMPG either in the begining of the conversion with Source Range, or after you have converted the entire file with MPEG Tools. -
I've fixed tons of .avi files. The best thing you can do is use VirtualDub to open the .avi in it. Depending on what quality the .avi file you have, you need to do two things. I don't know enough about the .avi file format to make the distinction, but if neither of these work, you can't do anything with it.
1. Open the movie and choose "direct stream copy" on both video and audio and save a new copy of the movie. This is good for incompletely downloaded movies.
2. Open the movie and re-encode it to the same or a similar DivX codec. This is useful for more serious problems.
I personally use option 1 much more often, so try that, plus it's very quick, only a few minutes for an entire movie.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
Mov file with mono audio plays silently: fixed by opening Super
By aslaksen in forum Video ConversionReplies: 0Last Post: 7th May 2010, 19:35 -
AVI file only plays audio. no video
By lauren.eriksen in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2009, 20:56 -
DVR-MS file plays audio but no video
By mattman1968 in forum Software PlayingReplies: 12Last Post: 27th Feb 2008, 07:31 -
My backup AVI file plays choppy
By rayc1234 in forum Newbie / General discussionsReplies: 14Last Post: 11th Aug 2007, 14:39
