  1. How can I play this audio or encode to a more playable format.
    I can only play the first audio file 192kbps but I want a better quality and also
    want a 5.1 in the best quality. Can anybody help me out. Thanks alot
    Audio #1
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Mode extension : Intensity Stereo + MS Stereo
    Codec ID : 3
    Duration : 5mn 29s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : -17ms
    Stream size : 7.54 MiB (1%)
    Language : English
    Audio #2
    ID : 257 (0x101)-1
    Menu ID : 1 (0x1)
    Format : Dolby E
    Mode : 20
    Format settings, Endianness : Little
    Muxing mode : AES3
    Codec ID : 6
    Duration : 5mn 29s
    Encoded bit rate : 2 304 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Bit depth : 20 bits
    Delay relative to video : -239ms
    Language : English
    Audio #3
    ID : 257 (0x101)-2
    Menu ID : 1 (0x1)
    Format : Dolby E
    Mode : 20
    Muxing mode : AES3
    Duration : 5mn 29s
    Encoded bit rate : 0 bps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Bit depth : 20 bits
    Audio #4
    ID : 257 (0x101)-3
    Menu ID : 1 (0x1)
    Format : Dolby E
    Mode : 20
    Muxing mode : AES3
    Duration : 5mn 29s
    Bit depth : 20 bits
    Audio #5
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Codec ID : 3
    Duration : 5mn 29s
    Bit rate : 384 Kbps
    Delay relative to video : -16ms
    Stream size : 15.1 MiB (1%)
    Language : English
    Audio #6
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Codec ID : 3
    Duration : 5mn 29s
    Bit rate : 384 Kbps
    Language : English
  2. https://github.com/kierank/broadcastencoder/wiki
    "E-distribution audio"
    Commercially known as "Dolby E" - Contact kierank for more information about licensing.
  3. Originally Posted by pandy View Post
    Thanks for your help it looks complicated but ill give it a shot lol
