i hav mpg file to burn as VCD
the file is in NTSC format
in one of the setting option in Nero, it asked me to choose
either PAL or NTSC
but i later found out that i need the PAL version not the NTSC version. so can i choose PAL option in Nero or do i need to reencode the whole mpeg again using tmpg into PAL format?
ur help pls.
Re-encode your MPEG file as a PAL file instead of NTSC, then burn it in NERO as PAL.
Where is the MPEG-2 selection in the summary tab To Target Setting
By RL in forum ffmpegX general discussionReplies: 3Last Post: 31st Jan 2011, 15:42 -
Premiere MPEG for DVD setting
By CircusAim in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2010, 11:23 -
setting region with AVS and a Nero question
By Willy Bee in forum Authoring (DVD)Replies: 2Last Post: 21st Feb 2010, 22:21 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Recommend a GOP setting for PAL-DVD/MPEG 2 files?
By Dark Alpha in forum EditingReplies: 1Last Post: 25th Jan 2008, 21:41
