Hi,
I recently upgraded my VLC to Version 2.1.2. Since then I'm having problems playing MP4 video files. When I paly the file I get the audio but no video, only a black screen. The problem doesn't seem to happen with all MP4s but it does with most of them.
I've tried reverting versions of VLC, but the problem is still there.
I'm using VLC version 2.1.2 on Windows 7 Home 64 bit.
Here are my messages:
main debug: adding item `Clip 1.mp4' ( file:///D:/George/Videos/Gilisoft/Clip%201.mp4 )
qt4 debug: Adding a new MRL to recent ones: file:///D:/George/Videos/Gilisoft/Clip%201.mp4
main debug: Creating an input for 'Clip 1.mp4'
main debug: meta ok for (null), need to fetch art
main debug: looking for meta fetcher module matching "any": 1 candidates
lua debug: Trying Lua scripts in C:\Users\George\AppData\Roaming\vlc\lua\meta\fetch er
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\fetcher
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
main debug: using meta fetcher module "lua"
main debug: removing module "lua"
main debug: searching art for Clip 1.mp4
main debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\George\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.lua c
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.lua c
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
main debug: no art finder modules matched
main debug: art not found for Clip 1.mp4
main debug: processing request item: Clip 1.mp4, node: Playlist, skip: 0
main debug: rebuilding array of current - root Playlist
main debug: rebuild done - 1 items, index 0
main debug: starting playback of the new playlist item
main debug: resyncing on Clip 1.mp4
main debug: Clip 1.mp4 is at 0
main debug: creating new input thread
main debug: using timeshift granularity of 50 MiB, in path 'C:\Users\George\AppData\Local\Temp'
main debug: `file:///D:/George/Videos/Gilisoft/Clip%201.mp4' gives access `file' demux `' path `/D:/George/Videos/Gilisoft/Clip%201.mp4'
main debug: creating demux: access='file' demux='' location='/D:/George/Videos/Gilisoft/Clip%201.mp4' file='D:\George\Videos\Gilisoft\Clip 1.mp4'
main debug: looking for access_demux module matching "file": 12 candidates
main debug: no access_demux modules matched
main debug: creating access 'file' location='/D:/George/Videos/Gilisoft/Clip%201.mp4', path='D:\George\Videos\Gilisoft\Clip 1.mp4'
main debug: looking for access module matching "file": 20 candidates
filesystem debug: opening file `D:\George\Videos\Gilisoft\Clip 1.mp4'
main debug: using access module "filesystem"
main debug: Using stream method for AStream*
main debug: starting pre-buffering
main debug: received first data after 0 ms
main debug: pre-buffering done 1024 bytes in 0s - 1000000 KiB/s
main debug: looking for stream_filter module matching "any": 6 candidates
main debug: no stream_filter modules matched
main debug: looking for stream_filter module matching "record": 6 candidates
main debug: using stream_filter module "record"
main debug: looking for demux module matching "mp4": 63 candidates
qt4 debug: IM: Setting an input
mp4 debug: dumping root Box "root"
mp4 debug: | + ftyp size 32
mp4 debug: | + free size 8
mp4 debug: | + mdat size 956923841
mp4 debug: | + mdat size 8
mp4 debug: | + moov size 1499695
mp4 debug: | | + mvhd size 108
mp4 debug: | | + trak size 606470
mp4 debug: | | | + tkhd size 92
mp4 debug: | | | + edts size 36
mp4 debug: | | | | + elst size 28
mp4 debug: | | | + mdia size 606334
mp4 debug: | | | | + mdhd size 32
mp4 debug: | | | | + hdlr size 45
mp4 debug: | | | | + minf size 606249
mp4 debug: | | | | | + vmhd size 20
mp4 debug: | | | | | + dinf size 36
mp4 debug: | | | | | | + dref size 28
mp4 debug: | | | | | | | + url size 12
mp4 debug: | | | | | + stbl size 606185
mp4 debug: | | | | | | + stsd size 137
mp4 debug: | | | | | | | + avc1 size 121
mp4 debug: | | | | | | | | + avcC size 35
mp4 debug: | | | | | | + stts size 252744
mp4 debug: | | | | | | + stss size 8632
mp4 debug: | | | | | | + stsc size 28
mp4 debug: | | | | | | + stsz size 172320
mp4 debug: | | | | | | + stco size 172316
mp4 debug: | | + trak size 892951
mp4 debug: | | | + mdia size 892815
mp4 debug: | | | | + minf size 892730
mp4 debug: | | | | | + smhd size 16
mp4 debug: | | | | | + stbl size 892670
mp4 debug: | | | | | | + stsd size 106
mp4 debug: | | | | | | | + mp4a size 90
mp4 debug: | | | | | | | | + esds size 54
mp4 debug: | | | | | | + stts size 24
mp4 debug: | | | | | | + stsc size 450700
mp4 debug: | | | | | | + stsz size 269512
mp4 debug: | | | | | | + stco size 172320
mp4 debug: | | + udta size 158
mp4 debug: | | | + meta size 150
mp4 debug: | | | | + hdlr size 33
mp4 debug: | | | | + ilst size 105
mp4 debug: | | | | | + ctoo size 35
mp4 debug: | | | | | + ccmt size 62
mp4 debug: ISO Media file (isom) version 512.
mp4 debug: found 2 tracks
mp4 warning: elst box found
mp4 debug: - [0] duration=1437270ms media time=0ms) rate=1.0
mp4 debug: track[Id 0x1] read 43075 chunk
mp4 debug: track[Id 0x1] read 43075 samples length:1437s
main debug: selecting program id=0
mp4 debug: adding track[Id 0x1] video (enable) language undef
mp4 debug: - [0] duration=1437291ms media time=0ms) rate=1.0
mp4 debug: track[Id 0x2] read 43076 chunk
mp4 debug: track[Id 0x2] read 67373 samples length:1437s
mp4 debug: adding track[Id 0x2] audio (enable) language undef
main debug: using demux module "mp4"
main debug: looking for a subtitle file in D:\George\Videos\Gilisoft\
main debug: looking for decoder module matching "any": 39 candidates
avcodec debug: trying to use direct rendering
avcodec debug: allowing 3 thread(s) for decoding
avcodec debug: avcodec codec (H264 - MPEG-4 AVC (part 10)) started
avcodec debug: using frame thread mode with 3 threads
main debug: using decoder module "avcodec"
main debug: using decoder module "faad"
main debug: looking for meta reader module matching "any": 2 candidates
main debug: using meta reader module "taglib"
main debug: removing module "taglib"
main debug: `file:///D:/George/Videos/Gilisoft/Clip%201.mp4' successfully opened
mp4 debug: elst (0) gives 0ms (movie)-> 0ms (track)
mp4 debug: track[Id 0x1] using Sync Sample Box (stss)
mp4 debug: stts gives 0 --> 0 (sample number)
mp4 debug: track[Id 0x2] does not provide Sync Sample Box (stss)
main debug: Buffering 0%
main debug: Buffering 33%
faad warning: decoded zero sample
main debug: Buffering 66%
main debug: Buffering 100%
main debug: reusing audio output
directsound debug: Opening DirectSound Audio Output
main debug: Stream buffering done (400 ms in 1 ms)
main debug: looking for text renderer module matching "any": 2 candidates
freetype debug: Using Arial as font from file C:\Windows\Fonts\arial.ttf
freetype debug: using fontsize: 2
main debug: using text renderer module "freetype"
main debug: looking for video filter2 module matching "any": 55 candidates
swscale debug: 32x32 chroma: YUVA -> 16x16 chroma: RGBA with scaling using Bicubic (good quality)
main debug: using video filter2 module "swscale"
yuvp debug: YUVP to YUVA converter
main debug: using video filter2 module "yuvp"
main debug: Deinterlacing available
main debug: deinterlace 0, mode blend, is_needed 0
main debug: Opening vout display wrapper
main debug: looking for vout display module matching "any": 10 candidates
direct3d debug: creating Vout EventThread
direct3d debug: DirectXCreateWindow
main debug: looking for vout window hwnd module matching "qt4,any": 3 candidates
qt4 debug: requesting video window...
directsound debug: Windows speaker config: Stereo and stream has 2 channels, using 2 channels
main debug: output 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
main debug: looking for audio volume module matching "any": 2 candidates
main debug: using audio volume module "float_mixer"
main debug: input 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
main debug: looking for audio filter module matching "scaletempo": 14 candidates
scaletempo debug: format: 48000 rate, 2 nch, 4 bps, fl32
scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
scaletempo debug: 1.000 scale, 1440.000 stride_in, 1440 stride_out, 1152 standing, 288 overlap, 672 search, 2400 queue, fl32 mode
main debug: using audio filter module "scaletempo"
main debug: conversion: 'f32l'->'f32l' 48000 Hz->48000 Hz Stereo->Stereo
main debug: conversion pipeline complete
main debug: looking for audio resampler module matching "any": 3 candidates
main debug: using audio resampler module "samplerate"
main debug: End of audio preroll
qt4 debug: Video was requested 0, 0
main debug: using vout window hwnd module "qt4"
direct3d debug: created video sub-window
direct3d debug: Vout EventThread running
direct3d debug: disabling screen saver
direct3d debug: Direct3d Device: ATI Mobility Radeon HD 4670 4098 38024 0
main debug: VoutDisplayEvent 'resize' 1296x758 window
direct3d warning: trying surface pixel format: YV12
direct3d debug: selected surface pixel format is YV12
direct3d debug: Using D3DTEXF_LINEAR for minification
direct3d debug: Using D3DTEXF_LINEAR for magnification
direct3d debug: Direct3D scene created successfully
direct3d debug: Direct3D device adapter successfully initialized
main debug: using vout display module "direct3d"
main debug: original format sz 1280x720, of (0,0), vsz 1280x720, 4cc I420, sar 1:1, msk r0x0 g0x0 b0x0
main debug: VoutDisplayEvent 'resize' 1600x759 window
main debug: removing module "freetype"
avcodec debug: using direct rendering
main debug: Decoder buffering done in 187 ms
main debug: inserting 1119 zeroes
main warning: playback too late (60562): up-sampling
main debug: auto hiding mouse cursor
main debug: resampling stopped (drift: -9375 us)
Any help would be greatly appreciated.
G
Yes. The videos play fine in DivX Player. I haven't tested all of them, but all the ones I have tested also play fine in Windows Media Player.
Thanks for the reply,
G
VLC: Jerky MP4 playback
By terrypin in forum Newbie / General discussionsReplies: 19Last Post: 13th Apr 2016, 19:43 -
mp4 video not playing for the full length in vlc player
By sumeshkri in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 17:50 -
How to integrate subtitle with mp4 video on VLC
By morsino in forum Video ConversionReplies: 3Last Post: 9th Jul 2010, 20:48 -
Corrupt MP4 and FLV Files - VLC Plays different Video
By ColdCoffee in forum Software PlayingReplies: 2Last Post: 25th Apr 2010, 08:32 -
Trouble playing mp4 in VLC, audio is there, but no video
By brdhsby5 in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2010, 13:06
