Hi there everyone,
I was just asking myself if someone could help me with the ffmpeg command line to convert a 720X576 mpeg
to those particular specs :
video: Apple PRO RES 422HQ 1920x1080 ~220 Mb/s, 25 fps, YUV colorspace
audio: mp2, 48 kHz, 16 bits, 384 kb/s, 2 channels (stereo)
Thanks in advance,
Results 1 to 22 of 22
Was the word itunes originally in your topic or was it added later? The specs you list do NOT conform to the itunes asset guide.
Well that's perhaps a mistake of me,
I was given those specs as Itunes Specs.
By the way thanks a lot for the help.
i guess the answer to my last question is to put -b:v 156k to my command line.
vincent
http://images.apple.com/itunes/lp-and-extras/docs/iTunes_VideoandAudio_Asset_Guide5.0.pdf
My original assumption from your first post was that you were going to use the footage to edit, probably in FCP. If this is going to iTunes there's no reason to upscale and your audio must be pcm_le.
But again, I'm guessing at what you're trying to do.
Best of luck
I only need to respect certain specs so my file can be uploaded by an automatic system.
can't manage to put my file up to 150mbs.
it's not a matter of quality, it's only an obligation so my file can be uploaded to the system.
could you help me with that bitrate issue.
Thanks in advance.
vincent
That's for work, the system have been built like that, please don't ask me why
so I've tried what you told me and it didn't work so afterwise i've tried to set a minrate and a maxrate but it didn't work.
are these options disabled with prores codec or what ?
Any other clue how to go up to a minimum of 150 mbs?
By the way I've checked the itunes music video assets and the specs seems pretty much the same as the one I gave you,
I'm I right with that?
#Music Video HD Source Profile
The -v:b 150M parameter works in the build I'm using dated Jan 22, 2014. Things change from version to version in ffmpeg, as you know.
Looks like itunes music video does indeed want mpeg 2 audio. It also seems to want to be in an mpg container instead of mov. I usually deal with "regular" videos so have never encountered this particular combination. Elsewhere it says they do not want uprezzed material, but that may not apply to you.
Well Many thanks for your replies and answers I guess I will not ask you anymore answers i solved the problem by choosing some Itunes SD format. whick is better for the kind of videos I have.
Thank you a lot.
Vincent
It suggests your material isn't very complex (encoding wise your material is very compressible), and has already saturated the prores encoder . It's probably not HD material, or very static/no motion .
ffmbc's prores encoder can achieve higher bitrates than ffmpeg's with -qscale 1
The other option if you must mean minimum bitrate requirements is to add fine noise/grain , even fine dithering will increase the bitrate
So it's me again.
here's my command line;
ffmbc -i input.mpg -vcodec prores -qscale 1 -acodec mp2 -sample_fmt s16 -ar 48000 -ab 384k -ac 2 -vf scale=1920:1080 output3.mov
everything is working just fine except my audio bit depth still is 32bit Float IEEE weird isn't it?
Well nevermind I get that by using vegas pro.
probably an error from my part.
Thank you both for your help.
I wish I won't need to ask you more questions.
Thanks.
How do I deinterlace 1080i ProRes 422 MOV files?
By Skycap in forum Newbie / General discussionsReplies: 2Last Post: 12th Nov 2012, 20:03 -
Need to convert ProRes to 422 HD MPEG2 program stream.
By Randy Burleson in forum Video ConversionReplies: 8Last Post: 27th Jul 2012, 18:24 -
FFMPEG Prores Encoder?
By Guiboche in forum Video ConversionReplies: 19Last Post: 11th May 2012, 17:40 -
Apple Prores 422 in MPEG Streamclip for Mac
By blanco in forum MacReplies: 5Last Post: 7th Jul 2011, 02:05 -
ProRes 422 (LT) 4.29GB wont open
By RenderFi in forum MacReplies: 8Last Post: 11th Dec 2010, 10:54
