Hi
I hope this is the right forum.
I want to know if there is any easy way to add chapters to a muxed mkv and have the chapters working on my WDTV Live?
I guess you have to manually use mkvtoolnix in mac.
Should work with Hybrid:
- start Hybrid
- set "Main->Primary Input Selection->Video handling" to "passthrough" (to make sure the video is not touched)
- set "Main->Primary Input Selection->Audio handling" to "passthrough all" (to make sure the audio is not touched)
- set "Config->Output->Container Settings->General Settings->Standard output container" to "mkv"
If you require some special mkv compatibility settings to be enabled, check out "Config->Output->Container Settings->Mkv Settings" and dis-/enable what you need. - enable "Config->Automation->Passthrough streams->Subtitle" (to make sure the subtitles are not touched)
- enable "Config->Automation->On Load->Always extract timecodes from mp4/mkv/flv files" (to make sure vfr timecodes will be kept even if MediaInfo reports the file as cfr)
- set "Config->Path->Default output path" or enable "Config->Path->Adjust->Output path to source path"
- enable "Main->Generate"
- drag&drop all the file you want to process onto the input line (Hybrid will then start to analyze the files)
- Switch to the Chapter tab and add the chapter you want
- press "Main->Add to Queue"; Hybrid will then create all the necessary jobs for your files
- start the processing by pressing "Jobs->Start"
Cu Selur -
if you are familiar with XML, mkvtoolnix supports chapters in details as xml inputs.
it even support an easy non-xml chapter format,.. http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge.html#mkvmerge.chapters
DVB-S2 - TS file plays fine, jerky when muxed to MKV
By DragonQ in forum DVB / IPTVReplies: 0Last Post: 16th Dec 2011, 15:58 -
Trouble With Improperly Muxed MKV
By Startropic1 in forum Video ConversionReplies: 1Last Post: 16th Jul 2011, 19:41 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 16:47
it has a lot of tool-tips which should explain some stuff, but Hybrid is mainly ment for users which know what they do
