ive heard that dell has hardware that is only fit for their computers. i have terrible ocd and adhd so i want to figure out if dell ram can fit with an hp m1170n computer. it might seem stupid im sorry.
I think older Dell power supplies and possibly motherboards used to be unique to Dell PCs, but I've never heard of special RAM. You should be able to use any RAM that has the correct specifications. The HP M1170n laptop seems to use DDR-400 (PC3200) DIMM Memory. No idea what the Dell you are asking about uses. But you can look it up on line.
Visit crucial.com and enter your Dell model number and you'll get the RAM specs. Match it up with the specs for your HP (here's a link to the HP page: http://www.crucial.com/search/searchresults.aspx?keywords=m1170n). And if they match, you're good to go!
As redwuz said, Dell had / has a lot of odd proprietary parts, but RAM isn't one of them. That said, some Dells (primarily servers) use less common RDRAM or ECC RAM which can only be used in compatible systems.
Question on configuring a RAM disk on WinXP 32-bit SP3
By PartingShot in forum ComputerReplies: 12Last Post: 4th Sep 2011, 14:13 -
Question on DDR2 RAM
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 08:01 -
Window 7 Usable RAM question
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 10th Apr 2011, 08:19 -
Simple Hardware question's on Ram and its support.
By avengerevenge in forum ComputerReplies: 2Last Post: 8th Jul 2010, 09:35 -
Dell Makes an I7 System for $1K
By Soopafresh in forum ComputerReplies: 15Last Post: 28th Jan 2009, 17:26
