    Jan 2014
    United States, CO
    Hello! This is my first time dealing with subtitles, and I'm having a lot of trouble. So, I had a company send me a .mov with subtitles. It plays in QuickTime with the subtitles no problem. I needed to be able to upload said video to Vimeo, so that I could share it. However, upon uploading (via DropBox) it does not have the subtitles!
    I did a little research, and poked around and heres what I found out. When I play the video in quicktime, there is no option for subtitles, it acts as if they aren't there. I downloaded VLC Media Player to test it out, and when played, it opened up two separate videos, one with the subtitles only, and the other was the actual film. I also found out the video was made with this editor http://www.supramotion.de/sublime/
    Here are some screenshots:
    Subtitles in Vimeo Thumbnail:
Name:	Screenshot 2014-01-25 13.27.45(2).png
    Vimeo Video Without Subtitles
Name:	Screenshot 2014-01-25 13.27.46.png
    QuickTime Playing subtitles, but not appearing in subtitles menu
Name:	Screenshot 2014-01-25 13.27.42.png
    VLC Playing 2 Videos
Name:	Screenshot 2014-01-25 13.27.45.png
    Oct 2005
    666th portal
    some actual information about the video would be nice. try installing the free mediainfo program, once installed you should be able to right click on the video file, put mediainfo into text mode and copy/paste the results here.
  3. This is a common problem when uploading a video with SOFTSUB, i.e. switchable subtitle.
    You will need to extract the subtitle stream first (http://www.youtube.com/watch?v=ePzwPwziKKQ)
    And if vimeo supports CC caption like youtube, you can upload the SRT subtitle file.
    Another method will be re-encoding the whole video with the subtitle becoming a part of video (HARDSUB, non-switchable)
