I am trying to rip some video from separate DVDs to combine them onto one DVD with a menu that will allow me to select each video. The problem I'm having is that I can't find a program that will do this AND keep the original chapter markers.
I have tried ripping to VOB, ISO, and MKV to see if that would make a difference, but it didn't help. The ripped files have the chapter markers, but they are lost when I combine them onto a DVD with a menu. I have DVDFAB 9 and Freemake Video Converter, but I am willing to buy another program if it will do what I need. Does anyone have any recommendations for programs that can do this?
dvdremake wasn't very intuitive so I gave up trying to figure it out.
I found a program called Womble EasyDVD, which is very easy to use and
retains the chapter markers perfectly. It also creates highly
customizable menus. Unfortunately, it doesn't shrink the final ISO to
the right size. It ends up being slightly too big to burn on the DVD.
So I just used it to create an ISO that is not shrinked to fit and
then I used dvdshrink to shrink the ISO down to the right size. This
produced a perfect result.
http://www.womble.com/products/features-easydvd.html
Final Cut Chapter Markers
By HaffHaff14 in forum MacReplies: 3Last Post: 13th Nov 2013, 13:14 -
Video format with chapter markers?
By whoisquilty in forum MacReplies: 9Last Post: 25th Mar 2011, 17:29 -
Adding Chapter Markers
By Big Jake in forum Authoring (DVD)Replies: 11Last Post: 11th Sep 2010, 23:50 -
Want to keep chapter markers with Vob2MPG in single mpeg
By Pontyac in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Jan 2010, 12:14 -
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 18:56
