When converting OGG movies in TMPEnc there are several movies which I can't convert to MPG because of the error 'ACM is not initialized'. I use the new 2.5 version and had the same problem with older versions.
I have installed all required codecs (LameACM, OGGDs filters etc...) and with playing OGG everything is fine.
Has anybody an idea what's wrong in TMPGEnc...
TIA...
Did you figure this out yet? Anyone else?
Tried Nimo's codecs - no go.
THe nuT -
By OGG movies I guess you mean Divx movies using the OGG audio codec. I havn't tried this but if you can play the movies in WMP this should work. Open the .avi file in virtualdub. On the audio menu select compression->PCM (no compression), full processing mode. Then from the file menu select save wav file. This will produce an uncompressed audio file, probably larger in size that the original avi! Load this into Tmpgenc as the audio stream, with your avi as the video stream and encode.
Let me know if this works
PS, when saving the audio file it is probably a good idea to do the rate conversion in virtualdub at this point too, if needed. It is quicker than using Tmpgenc to do this and better quality audio too. -
Vdub woultn't open the file for me - using the latest ver of vdub.
So, Any other ideas? -
Can you even load the file into TmpGenc. If so you can use file->output to file->wave file and save the audio out that way. The you can encode the video and audio seperatley.
No go with the ouput to wave file either.
This is perplexing.
Thanks for all your input. -
I am having the same problem. Would someone in the know please tell us how to convert and .ogg movie (by that I mean xxxx.ogm) into a format that can be converted to SVCD or DVD?
How do you burn initialized DVD discs?
By Djard in forum MediaReplies: 6Last Post: 24th Jul 2011, 12:26 -
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 21:30 -
AC3 ACM Will Not Install with Vista 64
By Mitchum22 in forum AudioReplies: 4Last Post: 19th Aug 2009, 09:15 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 08:16 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 26th Jul 2007, 23:05
