I've been been trying to capture VHS using my EasyCap and VirtualDub, but I've noticed that every time there is an inserted frame it will be the same frame as the very first captured one. This is a problem when there will suddenly be several random (e.g.) blue frames on a bad section of the tape. Is there any way to prevent this, or even insert the previous frame again, rather than the very first one?
You can try turning off/on the "insert null frames..." option in Capture -> Timing.
Virtualdub dropped frames
By TB Player in forum Capturing and VCRReplies: 16Last Post: 9th Jul 2013, 12:48 -
adding blur filter on selection frames not present in virtualdub
By Ganesh Ujwal in forum EditingReplies: 1Last Post: 16th Jul 2012, 11:16 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 17:50 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33
