    Jan 2014
    USA
    I use ConvertX 4 to burn my DVD's, usually with no problems. (I already downloaded the ConvertX 5 update, but don't like it, so I'm using 4)
    Now I have some avi's that I'm trying to put on one disc. The first failed burn resulted in the 1st and 2nd files (episodes) on the DVD playing fine... but all the rest of them being out of sync on the audio. I have tried checking the box for "do not fix audio discontinuities"... but that made the problem worse... audio even farther out of sync. I have the format set to NTSC on ConvertX. All the files play fine (sync is good) in VLC --- but some files are 29 fps, some are 23 fps. Don't know if that's what's messing it up...? I even tried burning all the 29 fps files together alone & ConvertX still messed up the audio sync. I thought of setting the format to automatic instead of NTSC, but it says that "Automatic will use the format/frame rate closest to that of the first file in the project and apply it to the rest of the files"
    Also wondering if I should change the resolution from Full D1 to automatic? The resolution of these files is 512 x 384. I don't know what will help, and I have enough coasters!
    Any thoughts on how to get these seemingly fine files to burn properly to disc? Thanks for any help! I have a log of one of the failed burns, if that will help: The only warning I got was that my cellphone was plugged in to another Drive (F)
    2014-01-21 14:58:31 ---- ******************** Log session stop 2014-01-21 14:58:31.152 PID 5036********************
    2014-01-21 07:33:13 Info Folder C:\ConvertXToDVD\The Comeback 1 (2005)\ has been removed
    2014-01-21 07:33:11 Info BURN: WRITE SUCCESS: Disc written
    2014-01-21 07:33:11 Info BURN: Finalization Time 00:00:37 - Total completion time 00:12:02
    2014-01-21 07:32:34 Info BURN: Write finished in 00:11:25 - Finalization start here. Avg. burn rate 4.88
    2014-01-21 07:21:35 Info BURN: Lead-in burning time (mS) 26549
    2014-01-21 07:21:08 Info BURN: Write started 2056992 sectors to write
    2014-01-21 07:21:08 Info BURN: Init success: DVD+R
    2014-01-21 07:21:08 Info BURN: Writing speed requested x8.0, effective x8.0
    2014-01-21 07:21:08 Info BURN: Available write speed: 16x ,12x ,8x ,6x ,4x
    2014-01-21 07:21:08 Info BURN: Media ID: CMC MAG-M01-00
    2014-01-21 07:21:08 Info BURN: Media type: DVD+R
    2014-01-21 07:21:08 Info BURN: DMA Mode
    2014-01-21 07:21:08 Info BURN: Scanned files #27, folder #2 - total size 4211582976 b. (3.92 Gb.)
    2014-01-21 07:21:08 Info BURN: Inserted media type : DVD+R
    2014-01-21 07:21:07 Info BURN: Write started
    2014-01-21 07:20:57 ---- ***************** Encoding end **********************
    2014-01-21 07:20:57 Info Disc name: "The Comeback 1 (2005)"
    2014-01-21 07:20:43 Info BURN: Writable disc DVD+R inserted. Ready to write
    2014-01-21 07:20:42 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2014-01-21 07:20:42 Info BURN: Drive has Serial ATA physical interface
    2014-01-21 07:20:41 Info BURN: New Drive selected : 1:1:0 - ATAPI iHAS120 6 7L0E [E] (Ide)
    2014-01-21 07:20:41 Info Burned folder: "C:\ConvertXToDVD\The Comeback 1 (2005)\", Min. media size 3.92 Gb.
    2014-01-21 07:20:41 Info Total size 4016 Mb., Target size DVD5 4300 Mb., Occupation 93.41%
    2014-01-21 07:20:41 Info Conversion completed in 02:07:24
    2014-01-21 07:20:40 Info Rendering rate: 1.38 x Realtime
    2014-01-21 07:20:40 Info DVD duration (incl. menus) 02:55:48 (~ 10548 sec.) - rendering time 02:07:24
    2014-01-21 07:19:39 Info Generated duration 1700.70 sec., expected 1696.76 sec.
    2014-01-21 07:15:09 Info Chapter #6 start at 24:59.998
    2014-01-21 07:09:47 Info Chapter #5 start at 20:0.199
    2014-01-21 07:04:46 Info Chapter #4 start at 15:0.399
    2014-01-21 06:59:32 Info Chapter #3 start at 10:0.099
    2014-01-21 06:54:53 Info Chapter #2 start at 5:0.300
    2014-01-21 06:51:34 Info Stream #2 - Audio sync at 130.61 ms: 1018.78 ms added
    2014-01-21 06:51:33 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 06:51:33 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 06:51:33 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 4129 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 06:51:33 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 06:51:33 Info Chapter sequences require 123.36 Mb. temp space
    2014-01-21 06:51:33 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 06:51:33 Info AUDIO Stream #2 : Audio: mp3, 44100 Hz, stereo, s16, 112 kb/s
    2014-01-21 06:51:33 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 06:51:33 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 06:51:33 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.106.pdtv.[VTV].avi - 1 file(s) 233.40 Mb.
    2014-01-21 06:51:33 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 06:51:33 Info Video bitrate 0/4129/9008 Kbps (min/avg/max)
    2014-01-21 06:51:33 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 06:51:33 ---- ======================= TITLESET #6 =======================
    2014-01-21 06:51:33 Info Generated duration 1642.84 sec., expected 1638.94 sec.
    2014-01-21 06:51:08 Info 37 frames duplicated
    2014-01-21 06:50:05 Info Chapter #6 start at 24:59.998
    2014-01-21 06:46:27 Info Chapter #5 start at 20:0.199
    2014-01-21 06:43:03 Info Chapter #4 start at 15:0.399
    2014-01-21 06:39:57 Info Chapter #3 start at 10:0.099
    2014-01-21 06:36:40 Info Chapter #2 start at 5:0.300
    2014-01-21 06:33:12 Info Stream #2 - Audio sync at 120.00 ms: 744.00 ms added
    2014-01-21 06:33:12 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 06:33:12 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 06:33:12 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 3492 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 06:33:12 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 06:33:12 Info Chapter sequences require 123.36 Mb. temp space
    2014-01-21 06:33:12 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 06:33:12 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
    2014-01-21 06:33:12 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 06:33:12 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 06:33:12 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.105.pdtv-tv.[VTV].avi - 1 file(s) 233.40 Mb.
    2014-01-21 06:33:12 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 06:33:12 Info Video bitrate 0/3492/9008 Kbps (min/avg/max)
    2014-01-21 06:33:12 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 06:33:12 ---- ======================= TITLESET #5 =======================
    2014-01-21 06:33:12 Info Generated duration 1749.58 sec., expected 1745.65 sec.
    2014-01-21 06:30:13 Info Chapter #6 start at 24:59.998
    2014-01-21 06:26:49 Info Chapter #5 start at 20:0.199
    2014-01-21 06:23:41 Info Chapter #4 start at 15:0.399
    2014-01-21 06:20:20 Info Chapter #3 start at 10:0.099
    2014-01-21 06:16:54 Info Chapter #2 start at 5:0.300
    2014-01-21 06:13:29 Info Stream #2 - Audio sync at 120.00 ms: 744.00 ms added
    2014-01-21 06:13:29 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 06:13:29 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 06:13:29 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 3319 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 06:13:29 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 06:13:29 Info Chapter sequences require 123.36 Mb. temp space
    2014-01-21 06:13:29 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 06:13:29 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
    2014-01-21 06:13:29 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 06:13:29 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 06:13:29 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.104.pdtv-lol.avi - 1 file(s) 233.56 Mb.
    2014-01-21 06:13:29 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 06:13:29 Info Video bitrate 0/3319/9008 Kbps (min/avg/max)
    2014-01-21 06:13:29 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 06:13:29 ---- ======================= TITLESET #4 =======================
    2014-01-21 06:13:29 Info Generated duration 1682.85 sec., expected 1678.93 sec.
    2014-01-21 06:11:14 Info Chapter #6 start at 24:59.998
    2014-01-21 06:07:52 Info Chapter #5 start at 20:0.199
    2014-01-21 06:04:32 Info Chapter #4 start at 15:0.399
    2014-01-21 06:01:12 Info Chapter #3 start at 10:0.099
    2014-01-21 05:57:53 Info Chapter #2 start at 5:0.300
    2014-01-21 05:54:35 Info Stream #2 - Audio sync at 120.00 ms: 792.00 ms added
    2014-01-21 05:54:34 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 05:54:34 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 05:54:34 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 3289 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 05:54:34 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 05:54:34 Info Chapter sequences require 123.36 Mb. temp space
    2014-01-21 05:54:34 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 05:54:34 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
    2014-01-21 05:54:34 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 05:54:34 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 05:54:34 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.103.pdtv-lol.avi - 1 file(s) 233.54 Mb.
    2014-01-21 05:54:34 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 05:54:34 Info Video bitrate 0/3289/9008 Kbps (min/avg/max)
    2014-01-21 05:54:34 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 05:54:34 ---- ======================= TITLESET #3 =======================
    2014-01-21 05:54:34 Info Generated duration 1755.52 sec., expected 1751.60 sec.
    2014-01-21 05:51:40 Info Chapter #6 start at 24:59.998
    2014-01-21 05:48:25 Info Chapter #5 start at 20:0.199
    2014-01-21 05:45:18 Info Chapter #4 start at 15:0.399
    2014-01-21 05:41:54 Info Chapter #3 start at 10:0.099
    2014-01-21 05:38:41 Info Chapter #2 start at 5:0.300
    2014-01-21 05:35:23 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 05:35:23 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 05:35:23 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 3156 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 05:35:23 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 05:35:23 Info Chapter sequences require 123.36 Mb. temp space
    2014-01-21 05:35:23 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 05:35:22 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
    2014-01-21 05:35:22 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 05:35:22 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 05:35:22 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.102.pdtv-lol.avi - 1 file(s) 233.48 Mb.
    2014-01-21 05:35:22 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 05:35:22 Info Video bitrate 0/3156/9008 Kbps (min/avg/max)
    2014-01-21 05:35:22 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 05:35:22 ---- ======================= TITLESET #2 =======================
    2014-01-21 05:35:22 Info Generated duration 1981.07 sec., expected 1975.20 sec.
    2014-01-21 05:34:45 Info P-SDT buffer Underflow 1 times, 1265 bytes peak
    2014-01-21 05:34:45 Info 2 frames duplicated
    2014-01-21 05:33:16 Info Chapter #7 start at 30:0.298
    2014-01-21 05:29:46 Info Chapter #6 start at 24:59.998
    2014-01-21 05:26:32 Info Chapter #5 start at 20:0.199
    2014-01-21 05:23:13 Info Chapter #4 start at 15:0.399
    2014-01-21 05:20:01 Info Chapter #3 start at 10:0.099
    2014-01-21 05:16:39 Info Chapter #2 start at 5:0.300
    2014-01-21 05:13:20 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2014-01-21 05:13:20 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
    2014-01-21 05:13:20 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 3100 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2014-01-21 05:13:20 Info Video processing: Linear (VSO) resampler (512*384)->(720*480)
    2014-01-21 05:13:20 Info Chapter sequences require 142.89 Mb. temp space
    2014-01-21 05:13:20 ---- ************ Source file #1 END DETAILS ************
    2014-01-21 05:13:20 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
    2014-01-21 05:13:20 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 512x384 [PAR 1:1 DAR 4:3], 29.97 FPS
    2014-01-21 05:13:20 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2014-01-21 05:13:20 Info Logical file: G:\Erin's Stuff\TV\The Comeback\the.comeback.101.pdtv-lol.avi - 1 file(s) 234.69 Mb.
    2014-01-21 05:13:20 ---- *********** Source file #1 BEGIN DETAILS ***********
    2014-01-21 05:13:20 Info Video bitrate 0/3100/9008 Kbps (min/avg/max)
    2014-01-21 05:13:20 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2014-01-21 05:13:20 ---- ======================= TITLESET #1 =======================
    2014-01-21 05:13:20 Info 2 Stream(s) found - est. duration 00:27:44.763, reference 00:27:44.763
    2014-01-21 05:13:20 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.106.pdtv.[VTV].avi"
    2014-01-21 05:13:20 Info 2 Stream(s) found - est. duration 00:26:46.944, reference 00:26:46.944
    2014-01-21 05:13:20 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.105.pdtv-tv.[VTV].avi"
    2014-01-21 05:13:20 Info 2 Stream(s) found - est. duration 00:28:33.648, reference 00:28:33.648
    2014-01-21 05:13:20 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.104.pdtv-lol.avi"
    2014-01-21 05:13:19 Info 2 Stream(s) found - est. duration 00:27:26.928, reference 00:27:26.928
    2014-01-21 05:13:19 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.103.pdtv-lol.avi"
    2014-01-21 05:13:19 Info 2 Stream(s) found - est. duration 00:28:39.600, reference 00:28:39.600
    2014-01-21 05:13:19 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.102.pdtv-lol.avi"
    2014-01-21 05:13:19 Info 2 Stream(s) found - est. duration 00:32:07.200, reference 00:32:07.200
    2014-01-21 05:13:19 Info Opening file "G:\Erin's Stuff\TV\The Comeback\the.comeback.101.pdtv-lol.avi"
    2014-01-21 05:13:15 Info [ ] Multicore support in resize
    2014-01-21 05:13:15 Info Project size 4.17 Gb. (239.36 Mb. audio - 3.92 Gb. video)
    2014-01-21 05:13:15 Info [ ] Don't fix audio gaps
    2014-01-21 05:13:15 Info [ ] Engine Log
    2014-01-21 05:13:15 Info [ ] 2-pass encoding
    2014-01-21 05:13:15 Info Encoding preset: MP (Medium Projects)
    2014-01-21 05:13:15 ---- ****************** Encoding begin *******************
    2014-01-21 05:13:15 ---- **************** Menu settings end ******************
    2014-01-21 05:13:15 Info [ ] Don't create title menu for single video
    2014-01-21 05:13:15 Info [ ] Return to title menu after titleset playback
    2014-01-21 05:13:15 Info [x] Skip root menu initially
    2014-01-21 05:13:15 Info [x] Play titles one after the other
    2014-01-21 05:13:15 Info [ ] Loop playback
    2014-01-21 05:13:15 Info [ ] Auto-start playback
    2014-01-21 05:13:15 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
    2014-01-21 05:13:15 ---- *************** Menu settings begin *****************
    2014-01-21 05:13:15 ---- **************** Burn settings end ******************
    2014-01-21 05:13:15 Info Default speed selected: 1x
    2014-01-21 05:13:15 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2014-01-21 05:13:15 Info BURN: Drive has Serial ATA physical interface
    2014-01-21 05:13:15 Info BURN: New Drive selected : 1:1:0 - ATAPI iHAS120 6 7L0E [E] (Ide)
    2014-01-21 05:13:15 Info [x] Delete DVD folder after burn complete
    2014-01-21 05:13:15 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
    2014-01-21 05:13:15 Info SAO setting: Automatic
    2014-01-21 05:13:15 Info [x] Burn result to DVD / as ISO file in working folder
    2014-01-21 05:13:15 ---- **************** Burn settings begin ****************
    2014-01-21 05:13:04 Info 37 Menu templates loaded.
    2014-01-21 05:13:00 Info BURN: Writable disc DVD+R inserted. Ready to write
    2014-01-21 05:12:59 Info BURN: 2 writer(s) found.
    2014-01-21 05:12:59 Info BURN: Loaded DLL "C:\Program Files\ConvertX4 - newer\vso_hwe.dll" [4.0.16.484]
    2014-01-21 05:12:59 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2014-01-21 05:12:59 Info BURN: Drive has Serial ATA physical interface
    2014-01-21 05:12:59 Info BURN: New Drive selected : 1:1:0 - ATAPI iHAS120 6 7L0E [E] (Ide)
    2014-01-21 05:12:59 Warning BURN: Profile list not found: Code 00 00 00 [No sense information.] Page 2A not found: Code 00 00 00 [No sense information.]
    2014-01-21 05:12:59 Warning BURN: 0:0:0 - Device in use [F] not listed because it was impossible to detect if it's a writer. Error detail follow
    2014-01-21 05:12:57 Info BURN: Using SPTI interface
    2014-01-21 05:12:54 Info Supported instruction set: sse3
    2014-01-21 05:12:54 Info Maximum number of threads detected: 2 - parallelize up to 2
    2014-01-21 05:12:54 Info Tuning Performances for Intel(R) Pentium(R) 4 CPU 2.80GHz with 2 logical core(s)
    2014-01-21 05:12:54 Info System default language : English (United States)
    2014-01-21 05:12:54 Info User default language : English (United States)
    2014-01-21 05:12:54 Info Version : 4.1.19.364
    2014-01-21 05:12:54 Info ExeName : C:\Program Files\ConvertX4 - newer\convertxtodvd.exe
    2014-01-21 05:12:54 Info OS : Microsoft Windows XP Home Edition (Build 2600: Service Pack 3)
    2014-01-21 05:12:51 ---- ******************** Log session start 2014-01-21 05:12:51.731 PID 5036********************
    Jan 2007
    i will offer only this
    I do not author and burn in one step
    i author to the HD as a DVD folder,
    then i test the DVD folder on the PC if it plays in VLC with no problem, then i burn to disc using imgburn
    if anything is 'HINKY' i delete the folder and try again
    Mar 2008
    Six episodes in six titles. Just create a project with the source files that are giving you problems and test those.
    Don't waste any more disks, either use a read/writable, (DVD/RW) or have the program just create the video_ts folder
    and stop there. You can play it back and check it straight from the hard drive.
    Why would you keep wasting media?
