The text in my Firefox browser is fuzzy and difficult to read. I googled the problem and it seems very common in W8. I tried 2 of "fixes" and both failed to fix the problem. Does anyone know a fix that actually works?
Hard to tell which fixes you've tried, since you didn't list them.
I had to go into about:config in Firefox and set gfx.content.azure.enabled to false and set gfxdirect3d.last_used_feature_level_idx to 0.
This solved the issue for me. -
I tried your first suggestion to change the setting to false and that seems to have fixed the problem,thanks.
While I am not a fan of 8 at all, it is a firefox problem. I get the same thing in Windows 7. It started happening about two or three software versions ago. Mozilla has yet to fix it. I toggled the setting quite some time ago, but it broke something else, so I changed it back.
Believing yourself to be secure only takes one cracker to dispel your belief.
fuzzy text/desktop display with Sony Bravia TV
By Bacillus98 in forum Media Center PC / MediaCentersReplies: 12Last Post: 24th Feb 2016, 13:29 -
Text Fuzzy Blurry with HDMI cable
By andriask in forum DVB / IPTVReplies: 27Last Post: 18th Apr 2014, 07:40 -
rtf text editor that allows black background & white text
By deadmeow in forum ComputerReplies: 4Last Post: 13th Dec 2012, 17:50 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
windows 7 has shadowed text on desktop
By mysts in forum ComputerReplies: 2Last Post: 16th Oct 2009, 15:37
