Results 1 to 12 of 12
  1. Hi,
    My problem is my VirtualDub... I need do a compression of a video file (1,98 GB) but it doesn't work, when I do the compression the video is bigger than the original file (2,58 gb) ... I try everything but now I don't know what to do... the file is too big and I need past subs... I even try to use Handbrake but the file is bigger than virtualdub...
    I'm slowly learning about this... so I don't know much about it ¿Can anybody help me with this?
    PD: Sorry for my eng...
    Adjust the video bitrate. Under video -> compression and choose a codec like xvid codec. Click configure.
    You can use a bitrate calculator to calculate the exact bitrate for specific output file size.
  3. I use the codec xvid and I even use Divx but the file is the same... big
  4. Originally Posted by showsnsdespa View Post
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    But have you lowered the bitrate? Or increase the constant quantizer/quality value.
  6. This is very embarrassing but I don't know how... I'm new in all of this... ¿Do you mind explain me? and thank you very much
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I haven't used virtualdub and the xvid for a long time now.
    But have you found the xvid configure button?
    Something like http://www.digital-digest.com/articles/virtualdub_standalone_page4.html might help...but it looks probably a bit different now.
  8. I'm going to try all that you say I'm now compression the file with the filters.Thank you... I hope it can work...
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Filters?? No, just change the bitrate.
  10. I know but I'm using filters... like logo and subs :P
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Ooops. I missed that.
  12. ¡Ah! Thank you it work~~~~ finally
