Hi,
I followed the divx to vcd tutorial on this site and tried to burn the mpeg but i get this error:
VcdxBuild.exe Execution failed: image too big
Now, the original divx .avi is about 700mb, and the mpg that was created by tmpgenc is about 1.12GB, so does this mean I cannot burn the vcd because the mpg is way over 700mb? So I can only burn a really small divx say, a 400mb one to vcd because when I convert it to mpg it just blows up in size? Hmm any advice is appreciated here.
Thanks!
Techx
You have to cut the mpeg file split it in half !
use mpeg tools in TMPGEnc (merge & cut)
or you can use Vcd Cutter! :D -
Aw that sucks.. So even though the divx file is 700mb and easily fits on a CD-R, if I want it to be a vcd that plays on a dvd player, I need two cd's ? Doesnt bother me, but I was going to give it to a friend and it's annoying having to swap cd's in the middle of watching something.
thx -
I encode Divx stuff all the time into Mpegs so I can burn it to VCD & play it on my DVD Player. The Divx file is an .Avi file (Think of it like a Zip File). When you feed the Divx .Avi file into TMPEnc, it will encode it to an Mpeg file, your 700 MB Divx .Avi will now become like a 1400 MB Mpeg file! Don't feel bad, I encoded "Saving Private Ryan" today & wound up using (3) CD-R's!! (There weren't no other way to do it).
-Good Luck-
-Mike-
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 21:12 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 22:18 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 17:36 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
