the problem that i am having is that i can't play just this one vcd on my computer. my computer will play all other vcd and i am 100% sure that the vcd is working, because it will play on vcd players. the error message that i get when trying to play the vcd is "the format is unsupported". If anyone know what is wrong please help.
thx
Sounds like this VCD is non standard, when making them with TMPGEnc you must load a VCD template to create a standard fully compliant VCD, if you change anything, it may work on some players but not on others.
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
