Hi,
I was almost finished converting an .avi into .mpg with TMPGEnc when an error occured and the conversion stopped (okay, so there wasn't enough space on my hard drive...)
If I hit 'start' again, though, I get the message that the file already exists (of course, since I've already spent 7 hours converting 690MB) and I'm asked if I want to overwrite - which I DON'T, because there are already 690 out of 750MB encoded.
Is there no RESUME option?
Feli,
There is no resume option (not yet) in TMPGEnc
...but what you can do, is to change the range being encoded and then join the 2 files.
Regards,
John Brondum -
Thanks for the info! How do I change the range?Originally Posted by jbrondum
(glad that this forum says newbie conversion...) -
As soon as I use the cutter/joiner in Tmpgenc's MPEGTools Nero (and other burning prgs) complain that it is no longer a standard-compliant VCD.Originally Posted by jbrondum
Is this a known problem, and how can I avoid it from happening?
TIA"The future is no longer what it used to be" -
[Blushing in shame]Originally Posted by letmeinforgodsake
Should have seen that!
Thanx!
So am I...Originally Posted by Feli
)"The future is no longer what it used to be"
Virtualdub just crashed, Resume?
By Asesinato in forum RestorationReplies: 8Last Post: 4th Apr 2012, 12:10 -
Possible to resume partial downlaods in IE?
By ryangarfield in forum ComputerReplies: 6Last Post: 22nd May 2009, 04:47 -
Commands-how to resume a different VTS?
By MrMoody in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2009, 12:04 -
Resume function
By powersmo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th May 2008, 11:59 -
resume partial work done by ffmpegx somehow?
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 25th Jan 2008, 04:19
