Hello,
Is there any tool available to play/decode a video with format MPEG-4 Visual Simple Studio Profile Level 2 stream.
I had a MOV file with this kind of video.
Unfortunately quick time player is failed to play or recognize the media.
Please help.
Dave
SrViewer from Sony: http://www.sonycreativesoftware.com/srviewer should be able to playback MPEG-4 SStP files, don't know of any normal player (aside from some NLEs) which support MPEG-4 SStP.
(afaik. libav doesn't support it so vlc and (S)MPlayer will probably fail)
after some googling, there's also
- a FinalCut Plugin: http://www.sonycreativesoftware.com/srpm-10
- an Avid AMA Plugin: http://www.sonycreativesoftware.com/srpa-10Last edited by Selur; 10th Jan 2014 at 04:56.
Hi
Hope your answer for QT Player in Windows 7 ?
Any AVID player will help to decode SStP video.?
DaveLast edited by Dave1024; 10th Jan 2014 at 05:53.
What? You lost me now. Or is the 'QT Player' you are referring to not the Quicktime Player (http://www.apple.com/de/quicktime/download/) ?Hope your answer for QT Player in Windows 7 ?
If it is the Quicktime Player, like I wrote, as far as I know, there is no plugin for it to support MPEG-4 Simple Studio Profile content.
No, afaik decoding inside Avid (www.avid.com) is only possible through the AMA (Avid Media Access) plugin mentioned above. Players which simply state that they will support content from Avid will probably not support MPEG-4 Simple Studio Profile.Any AVID player will help to decode SStP video.?
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
Simple question about group files decoding
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 05:58 -
Directshow filter for decoding MPEG-2 TS
By roflwaffle in forum Video ConversionReplies: 5Last Post: 17th Aug 2010, 07:55 -
Decoding MPEG-4 HE-AAc v2 audio in Stereo from DVB-T Broadcast
By tolinn in forum DVB / IPTVReplies: 0Last Post: 10th May 2010, 11:49 -
ffmpeg and mpeg-4 visual simple profile level 3 (packed bitstream)
By Witchking in forum LinuxReplies: 2Last Post: 6th Oct 2009, 13:08
