Brief Specs.
Media Coder Build Version: 0.8.28.5588 [Most recent as of1/9/14 EST]
MKVExtractGUI Build Version: 2.2.2.8 [Most recent as of1/9/14 EST]
Computer Type: Laptop
Computer Brand: Acer
OS: Windows 8
System type: 64 bit
CPU: Intel Core i3-2377M @1.500 GHz
Ram: 4.00 GB
Issue: When transcoding a MKV file to MP4 with subtitles(MKV-> MP4) , Japanese Characters appear as boxes. (Similar to [] )
Details: There are English Translation(English text),Japanese Characters(Japanese Text/Characters), Japanese Words(English Text)Please view example below.
Example of issue:HardLink: http://imgur.com/OIqBWUj
I have been following the settings in this video:https://www.youtube.com/watch?v=fbCDTN--XGA
I understand that Media Coder does not work well withforeign languages like Japanese and Korean. However, previous MKV files I haveconverted with the same exact settings has worked with Japanese charactersshown. I have also tried to change my system locale to Japanese then run MediaCoder with no success.
I have looked at threads similar to my issue but no viablesolution.
Example File:Code:Examples: http://forum.mediacoderhq.com/viewtopic.php?f=17&t=12958 http://forum.mediacoderhq.com/viewtopic.php?f=17&t=12596 http://forum.mediacoderhq.com/viewtopic.php?f=17&t=11331
MKVExtractGUI "Ressurection" View of MKV streams:Hard Link: https://forum.videohelp.com/images/imgfiles/iTYAQPch.jpg
General Settings of file from Media Coder:
.SSA File in text form: [Dialogue is not added due to limitation of characters in a thread. Forfull text: http://pastebin.com/yDcmpsau]Code:General Unique ID :197668498465397754254016408331112405256 (0x94B5916A2124ECDFBBCFE490A8C7D908) Complete name :C:\Users\Holysam\Desktop\[UTWoots]_Sword_Art_Online - 01 [Raizu].mkv Format : Matroska Format version : Version 2 File size : 82.0 MiB Duration : 23mn 40s Overall bit rate mode : Variable Overall bit rate : 484 Kbps Encoded date : UTC 2012-07-0904:12:29 Writing application : mkvmerge v4.8.0 ('I GotThe...') built on May 24 2011 03:12:58 Writing library : libebml v1.2.0 +libmatroska v1.1.0 Attachment : Yes / Yes /Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes Video ID : 2 Format : AVC Format/Info : Advanced VideoCodec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Muxing mode : Headerstripping Codec ID :V_MPEG4/ISO/AVC Duration : 23mn 40s Bit rate : 394 Kbps Width : 848pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.040 Stream size : 66.8 MiB (81%) Writing library : x264 core 116 Encoding settings : cabac=1 / ref=8 /deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 /psy_rd=0.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 /8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 /threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0/ constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 /direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 /scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0/ qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=2:0.60 Language : English Default : Yes Forced : No Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 3 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 23mn 40s Bit rate mode : Variable Bit rate : 80.0 Kbps Channel count : 1 channel Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 13.5 MiB (17%) Writing library : aoTuV Beta 5 (UTC2006-10-24) Language : Unknown Default : Yes Forced : No Writing application : HandBrake Text ID : 1 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced SubStation Alpha Compression mode : Lossless Default : Yes Forced : No
Example working file:Code:[Script Info] ; Script generated by Aegisub 2.1.8 ; http://www.aegisub.org/ Title: Default Aegisub file ScriptType: v4.00+ WrapStyle: 0 PlayResX: 1280 PlayResY: 720 ScaledBorderAndShadow: yes Video Aspect Ratio: 0 Video Zoom: 8 Video Position: 291 Last Style Storage: Default Collisions: Normal Audio URI: ..\sao1_wr.v2_[81094606].mkv Scroll Position: 324 Active Line: 325 YCbCr Matrix: TV.601 Video File:[UTWoots]_Sword_Art_Online_-_01_[720p][E986EDE5]-OUT.mkv [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour,SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut,ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment,MarginL, MarginR, MarginV, Encoding Style: Default,Montara Gothic,50,&H00FFFFFF,&H000000FF,&H00211900,&H80000000,0,0,0,0,100,100,0,0,1,2.5,1,2,100,100,35,1 Style: Alternative,Montara Gothic,50,&H00D0DEF7,&H000000FF,&H00012150,&H80000000,0,0,0,0,100,100,0,0,1,2.5,1,2,100,100,90,1 Style: text1,Linux LibertineDisplay,50,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,0,2.5,2,10,10,10,1 Style: eol,WascoSans,24,&H002C254D,&H000000FF,&H00000000,&H00000000,-1,0,0,0,100,100,0,0,1,0,0,2,10,10,10,1 Style:msg,Raavi,38,&H00343434,&H000000FF,&H00F3F3F3,&H00000000,0,0,0,0,100,100,0,0,3,5,0,4,10,10,10,1 Style: char-menu,WascoSans,42,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,0,0,2,10,10,10,1 Style:title,Tunga,100,&H00D59F29,&H000000FF,&H00FFFFFF,&H00000000,-1,0,0,0,100,100,0,0,1,1.2,0,2,10,10,10,1 Style: location,Adobe CaslonPro,44,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,-1,0,0,0,100,100,0,0,1,0,3.5,2,10,10,10,1 Style:news,Raavi,30,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,1.5,0,2,10,10,10,1 Style: news2,WascoSans,20,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,1.5,0,2,10,10,10,1 Style:prev,Tunga,120,&H00D59F29,&H000000FF,&H00FFFFFF,&H00000000,-1,0,0,0,100,100,0,0,1,1.2,0,2,10,10,10,1 Style: Opening-Romaji-L0,Iwata Mincho Old Pro-EnH,48,&H00000000,&H00E3E3E9,&H3C7C7C80,&H00000000,-1,0,0,0,96,100,0,0,1,3.1,0,7,55,55,28,1 Style: Opening-Kanji-L0,Iwata Mincho Old Pro-EnH,42,&H00000000,&H00000000,&H3C7C7C80,&H00000000,-1,0,0,0,94,100,0,0,1,3.1,0,7,55,55,81,1 Style: Opening-English-L0,Iwata Mincho Old Pro-EnH,48,&H00E3E3E9,&H00000000,&H3C7C7C80,&H00000000,-1,0,0,0,92,100,0,0,1,3.1,0,1,55,55,30,1 Style: Opening-Romaji-L1,Iwata Mincho Old Pro-EnH,48,&H00E3E3E9,&H00AE8F2D,&H0083640D,&H00000000,-1,0,0,0,96,100,0,0,1,1.4,0,7,55,55,28,1 Style: Opening-Kanji-L1,Iwata Mincho Old Pro-EnH,42,&H00E3E3E9,&H00AE8F2D,&H0083640D,&H00000000,-1,0,0,0,94,100,0,0,1,1.4,0,7,55,55,81,1 Style: Opening-English-L1,Iwata Mincho Old Pro-EnH,48,&H00E3E3E9,&H00000000,&H0083640D,&H00000000,-1,0,0,0,92,100,0,0,1,1.4,0,1,55,55,30,1 [Events] Format: Layer, Start, End, Style, Name, MarginL, MarginR,MarginV, Effect, Text Comment:0,0:00:00.00,0:00:00.00,Default,,0000,0000,0000,,CREDITS\NTranslator:Crunchyroll\NTLC: Raze\NEditor: Raze\NTimer: killazys\NTypesetter:Justaway\NEncoder: killazys\NOP Translation: Raze\NQC: Raze, thecowgoesmoo,Spoggerific, Sapphi\NSpecial Thanks: kokujin-kun, Puff Comment:0,0:12:25.09,0:12:25.55,Default,,0000,0000,0000,,[from right to left]The ManWho Created The NervGear/The Rising Star of the Gaming World, KayabaAkihiko/Visual Basic Encyclopedia/(Introduction to PhysicalSimulation)/JavaScript Program Manual Comment:0,0:23:35.14,0:23:40.15,title,,0000,0000,0000,,{\fs75\pos(640,210)}Next Episode Comment:0,0:23:35.14,0:23:40.15,prev,,0000,0000,0000,,{\pos(640,595)}Beater
MKVExtractGUI "Ressurection" View of MKV streams:Image Hard Link: http://imgur.com/0SYCvCw
General Settings of working file from Media Coder:
Working .SSA File in text form: [Dialogue is not added due to limitation ofcharacters in a thread. For full text: http://pastebin.com/EVQN55j9]Code:General Unique ID :194494948825349190728665699578389370635 (0x92525D5642AE1D30A93B7519B526970B) Complete name :C:\Users\Holysam\Desktop\[SS-Eclipse] Zero no Tsukaima - Princess no Rondo -01.mkv Format : Matroska Format version : Version 1 File size : 59.3 MiB Duration : 23mn 39s Overall bit rate : 350 Kbps Encoded date : UTC 2008-07-1921:47:59 Writing application : mkvmerge v2.2.0 ('TurnIt On Again') built on Mar 4 200812:58:26 Writing library : libebml v0.7.7 +libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced VideoCodec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID :V_MPEG4/ISO/AVC Duration : 23mn 39s Nominal bit rate : 300 Kbps Width : 608pixels Height : 336 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.061 Writing library : x264 core 56svn-680 Encoding settings : cabac=1 / ref=1 /deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / brdo=0 / mixed_ref=0 /me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0/ threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1/ b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 /scenecut=40(pre) / rc=2pass / bitrate=300 / ratetol=1.0 /rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 /cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 Default : Yes Forced : No Audio ID : 2 Format : AAC Format/Info : Advanced AudioCodec Format profile : HE-AACv2 / HE-AAC/ LC Codec ID : A_AAC Duration : 23mn 39s Channel count : 2 channels / 1channel / 1 channel Channel positions : Front: L R / Front: C/ Front: C Sampling rate : 48.0 KHz / 48.0KHz / 24.0 KHz Compression mode : Lossy Default : Yes Forced : No Text #1 ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced SubStation Alpha Compression mode : Lossless Default : Yes Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Default : No Forced : No
Please give me a detailed solution of what I can do to fixthese boxes. I have looked everywhere and failed to find a solution.Code:[Script Info] ; Script generated by Aegisub v2.1.2 RELEASE PREVIEW (SVNr1987, amz) ; http://www.aegisub.net Title: Default Aegisub file ScriptType: v4.00+ WrapStyle: 0 PlayResX: 1280 PlayResY: 720 ScaledBorderAndShadow: yes Last Style Storage: Default Audio File: ?video Video Aspect Ratio: 0 Video Zoom: 2 Video Position: 24780 Collisions: Normal Video File: [WR]_ZnT_-_01_v2_[18F95912].avi [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour,SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut,ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment,MarginL, MarginR, MarginV, Encoding Style: Default,Edwardian MediumLET,54,&H00FFF5CA,&H0000FFFF,&H00400000,&H00400000,1,0,0,0,100,100,0,0,1,2,0,2,20,20,20,0 Style: Default-alt,Edwardian Medium LET,54,&H00EEDDFF,&H0000FFFF,&H00400040,&H00400040,1,0,0,0,100,100,0,0,1,2,0,2,20,20,20,0 Style: Spell,Edwardian MediumLET,54,&H00EEDDFF,&H0000FFFF,&H00400040,&H00400040,1,1,0,0,100,100,0,0,1,2,0,2,20,20,20,0 [Events] Format: Layer, Start, End, Style, Name, MarginL, MarginR,MarginV, Effect, Text Comment: 0,0:00:00.00,0:00:00.00,Default,,0000,0000,0000,, Comment: 0,0:00:00.00,0:00:00.00,Default,,0000,0000,0000,, Comment: 0,0:00:00.00,0:00:00.00,Default,,0000,0000,0000,, Comment: 0,0:00:00.00,0:00:00.00,Default,,0000,0000,0000,,
[UTWoots]_Sword_Art_Online - 01 [Raizu]--
Japanese subtitles for a DVD
By Patrion in forum ffmpegX general discussionReplies: 2Last Post: 5th Sep 2013, 18:32 -
Hardsub Japanese Subtitles.
By MountyBounty in forum SubtitleReplies: 4Last Post: 13th Sep 2012, 15:50 -
HELP: how to display Japanese subtitles
By andwan0 in forum SubtitleReplies: 1Last Post: 22nd Aug 2012, 09:50 -
subtitles in boxes help
By noobvide in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2012, 02:31 -
Possible to OCR Japanese subtitles?
By kpic in forum SubtitleReplies: 0Last Post: 11th May 2010, 19:39
