ok guys this is killing me and i need desprit help!!!
heres the prob, i am trying to convert my dvd to svcd before you tell me to go and look in the how to section i am using this guide J.o.D DVD to high quality SVCD conversion guide remeber i am ripping a pal region 2 dvd. its telling me to use a frame rate of 23.3 when setting up tmpgenc is this right for pal?
when i encode it and try to multiplex the audio its way way out of sync. so what i need is the correct settings (which will keep my audio and video in sync) and will also make it a complient svcd (which will be burned with nero). help with this would be most appreciated thanx.
Mikey :lol:
dont you think that i have done that? ive been messing around with it for the last few weeks!!! when i load and encode with teh pal template nero does not let me encode it it says that svcd is the wrong frame rate. and even when i know my self that i have encoded it in 25fps its saying that its a 29.9fps video??????? see if you know the anwser to this one!
Mikey :lol: -
an attitude like that doesn't make people want to help you at allOriginally Posted by m_lea1
I cannot offer any help with your current software, but I can make a suggestion. I use DVD2SVCD from www.doom9.org . This works excellectly and you dont need to make a lot of changes. The resulting SVCD is excellent. Try downloading the software and read the manual and I garentee that you will get the result you are after.
BTW. If you really are new to this, you may want to refrase your replies especialy to those offering help.
HMoose -
my intention was not to be offensive in my last reply. sorry if it came over that way but thanx for the suggestion truman.
i have attemped to use DVD2SVCD in the past and i have had poor results mibby it was the settings that i was using or something i cannot say. i might have a look in to some other way of encoding the svcd and ill let you know.Mikey :lol:
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 07:34 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 21:34 -
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 04:54 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 06:12 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 09:45
