Hi,
When i am capturing with my Webcam at 30fps, it doesnīt even stay at 30fps.
I know that often the Average rate will go up and down, so perhaps 30.1-29.9 etc, but at least be at about the place where it should be.
However, itīs at 29.874 or close to that, which isnīt close to 30, and it isnīt 29.97 either.
I am not sure what to think of it, as i am not that knowledgeable about this, the only thing i know is that there shouldnīt be any real problem, as the Webcam is through USB, compared to a capture device which can get inconsistent frames (Capture Cards without TBC).
Any ideas?
Specifications:
ThanksCode:Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504) Language: English (Regional Setting: English) System Manufacturer: System manufacturer System Model: System Product Name BIOS: BIOS Date: 06/26/12 19:24:30 Ver: 08.00.15 Processor: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz (4 CPUs), ~2.4GHz Memory: 8192MB RAM Available OS Memory: 8190MB RAM Page File: 7348MB used, 9033MB available Windows Dir: C:\Windows DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.02.9200.16384 64bit Unicode Webcam: c525 (Settings 640x480 30fps)
Results 1 to 1 of 1
Looking for 1080P 30FPS Webcam
By thebizguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 7th Nov 2012, 10:15 -
Newbie questions about frame rate (also VirtualDub)
By wallywalters in forum Video ConversionReplies: 5Last Post: 29th Oct 2012, 10:16 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 22:00 -
Cant join 2 avis with virtualdub because of different audio rate samples.
By supercain in forum EditingReplies: 5Last Post: 22nd Jul 2012, 06:38 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35
