Heya I'm a newbie at this...
I followed the directions on how to convert a DIVX AVI to MPG and then burn as VCD using NERO...
I am able to play the VCD file on my stand alone DVD player, however, some of the image is cropped, about 1 inch from the top of the screen and one inch from the bottom.
I tried w/ both NTSC and NTSC FILM, the file was 23.976 fps BTW. I live in the US and both my TV and DVD player use the NTSC standard... sigh I'm confused.. did I do something wrong?
Did you use the 3:2 pulldown when you encoded? Since the video was 23.976 you need to use the 3:2 pulldown so that the dvd player still thinks it is 29fps. I don't know if this is why your video got cropped but it could be.
Weeeee i figured it out... dunno why it cropped it
I fixed it by deselecting "Keep aspect Ratio" and selecting
"Center and use Custom size" what that did is make black borders on top bottome and left and right... I noticed the Panasonic Encoder's tutorial said that DIVX files often need to be changed in this manner, however the Panasonic Demo only lets you encode 30 seconds of film... anyways I'm glad Tmpeg has this feature as well... and it solved my problem ^^
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 14:17 -
Resolution and Aspect ratio
By Mrsash in forum Video ConversionReplies: 4Last Post: 19th Nov 2009, 16:37 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 07:23 -
Aspect Ratio/Resolution Question
By kidcash in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2007, 03:43 -
Tmpeg enc Plus 2.5 selects wrong Aspect ratio
By wozmac in forum Video ConversionReplies: 6Last Post: 15th Jul 2007, 17:31
