  1. Hello, this is my first post, so if this doesn't belong here I'm deeply sorry.
    My Problem:
    I was recording a Livestream with the "open Broadcaster Software" and upon reviewing the footage I realized that the sound didn't play.
    The Encoding settings for the audio are mp3 128bit.
    The File itself is a mp4 File
    MediaInfo has this to say:
    General
    Complete name : G:\recording\w1\recording (19).mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 5.51 GiB
    Duration : 4h 58mn
    Overall bit rate : 2 639 Kbps
    Encoded date : UTC 2014-01-05 18:19:29
    Tagged date : UTC 2014-01-05 18:19:29
    Writing application : Open Broadcaster Software v0.592b
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Container profile=High@3.1
    Codec ID : avc1
    Duration : 4h 58mn
    Source duration : 4h 58mn
    Bit rate : 2 500 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 fps
    Minimum frame rate : 29.412 fps
    Maximum frame rate : 30.303 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.040
    Stream size : 5.22 GiB (95%)
    Source stream size : 5.22 GiB (95%)
    Writing library : x264 core 140 r2380 3dcf6e2
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=cbr / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2500 / vbv_bufsize=2500 / nal_hrd=none / filler=1 / ip_ratio=1.40 / aq=1:1.00
    Color primaries : BT.709
    Transfer characteristics : sYCC
    Matrix coefficients : BT.709
    mdhd_Duration : 17937466
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 6B
    Duration : 4h 58mn
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : channel0
    Original Channel count : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 274 MiB (5%)
    Source stream size : 274 MiB (5%)
    Writing library : LAME3.99.5
    Premiere Pro doesn't recognize the audio, VLC crashes and Audacity can't open the file.
    Only the SMPlayer plays both audio and video correctly.
    Is there a way to 'save' the recording (extract the sound for further editing)?
    Every little bit of help is greatly appreciated
    Best wishes
    diocloid
    Try demux/extract the audio with mymp4boxgui or Pazera Free Audio Extractor.
  3. Wow, it worked...
    thank you very much
    /thread
