Hi
I have downloaded encrypted video from you can any1 tell me how to decrypt it.
You link is not working
Above one was download link below is video link
Sent from my GT-I9100 using Tapatalk 4Code:http://www.youtube.com/watch?v=qONk3IkTpBs
I already downloaded thru idm but video is encrypted and not playing in any player
Sent from my GT-I9100 using Tapatalk 4Code:General Complete name : D:\Youtube\War Chhod Na Yaa\War Chhod Na Yaar - YouTube.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 1.10 GiB Duration : 1h 48mn Overall bit rate mode : Variable Overall bit rate : 1 449 Kbps Encoded date : UTC 2013-11-12 18:45:25 Tagged date : UTC 2013-11-13 19:00:06 gsst : 0 gstd : 6532096 gssd : BADC23403HH1388949312337973 gshh : r9---sn-cvh7zn7y.c.youtube.com Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Codec ID : encv / avc1 / mp4a Duration : 1h 48mn Bit rate : 1 244 Kbps Maximum bit rate : 5 322 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.054 Stream size : 968 MiB (86%) Tagged date : UTC 2013-11-13 19:00:06 Encryption : Encrypted Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1h 48mn Bit rate mode : Variable Bit rate : 204 Kbps Nominal bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 158 MiB (14%) Title : IsoMedia File Produced by Google, 5-11-2011 Encoded date : UTC 2013-11-12 18:49:00 Tagged date : UTC 2013-11-13 19:00:06 Encryption : Encrypted
how i can watch downloaded youtube video as vide screen video.
By nusratjaveid in forum Video Streaming DownloadingReplies: 4Last Post: 6th Dec 2012, 21:15 -
How to edit/cut/join a Mpeg-TS encrypted video?
By jairovital in forum DVB / IPTVReplies: 11Last Post: 18th Nov 2012, 07:42 -
Youtube video looks different between my website and youtube.com
By jumpymonkey9 in forum Video Streaming DownloadingReplies: 0Last Post: 14th Oct 2011, 09:53 -
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 11:33 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 13:40
